#31
Re: More Carbon Sync Issues...Must Get Solved...
Yeah, a little strange for sure. I’m waiting for the next protools update. If it doesn’t make this go away I don’t think I’ll stay with Carbon either….pretty disappointing. Sent from my iPhone using Tapatalk
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate |
#32
Thanks as always for being polite and vocal.
I've pulled the priority up on this bug so it can be addressed a bit sooner. m
Mark Corbin Avid Sr Principal Product Manager Professional Audio Systems For immediate assistance: Pro Tools & Eucon Surfaces - +1 888-456-3444 Venue Support - +1 978-275-2557 Find out how to create, manage, and edit cases online now HERE It's fast, easy, and effective! |
#33
Great to hear. Thank you!
#34
Hello. Can you let us know if there’s been any progress on this issue? It was reported at least half a year ago now…enough time to fix something so serious Don’t you agree? If it’s that much trouble for avid engineers to track down and fix I’d like to know. Then I can decide on another route take. Sorry but it’s taking too long in my opinion. Sent from my iPhone using Tapatalk
#35
It is scoped and actively being worked on by developers. Delay Compensation issues are complex and it does not look like this one will make the next release. It is marked as a critical issue and is planned for the following release. Please understand it may slip from the expected fix version if we encounter other issues.
However, during our examination of the issue, we believe a viable workaround may be to set AFL/PLF Paths and Audition Path to None. I know it's not the info you wanted to hear, but I don't want to give you a song and dance either. m
#36
Thank you being truthful as always Mark.
Keep us informed on this issue. Sent from my SM-G998U using Tapatalk
What is more relaxing than Music? Pro Tools Carbon for macOS 12.7.4 My HDX for Windows11. Gigabyte Z490 Vision D - BIOS F21b Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1) Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity Bricasti M7 (2) Lexicon PCM96 Neumann KH805 - KH310 Yamaha NS-10M Avantone Mixcubes Grace Design M905 Etc, etc, etc. |
#37
Thanks I appreciate the straight up answer. Sent from my iPhone using Tapatalk
#38
Anyone know if the new update fixes any sync issues? I can’t check it for a few days. I hope so, there have been many updates since this was reported and acknowledged by Avid.
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate Last edited by CHRIS AIKEN; 05-26-2022 at 04:14 PM. |
#39
having what seem to be the same adc issues here too.
also experiencing weird issues where putting a track into DSP causes the left side of some of my auxes to go mute (very weird). making the track inactive then active again, then toggling DSP mode solves it every time. extremely annoying while tracking. anyone else have issues like this? pt studio 2022.5 mac os 10.15.7 |
#40
I think i have same issue:
If I record a DSP track set to outputs 1&2 and the rest of the tracks set to a master bus, all is in sync. On playback If the change the tracks output from 1&2 to the same master bus as the other track the newly recoded track is out of sync. If i assign the track to any other bus (bus 3&4) its back in sync. Thoughts ? Thanx |
Carbon Phase issues with hardware inserts | alhardy | Pro Tools | Carbon | 5 | 08-10-2023 11:03 AM |
Sync Problems with Carbon Downstream | tomhartman | Pro Tools | Carbon | 7 | 07-01-2021 02:15 PM |
Using Carbon with Avid Sync HD? | akhafaji | Pro Tools | Carbon | 1 | 01-18-2021 12:03 AM |
Radar II sync to Pro Tools ***Solved*** | GuyPicks | Pro Tools TDM Systems (Mac) | 5 | 06-13-2008 09:04 AM |
