Is there a plugin that does this?
Is there a plug in that does something similar to what is described in this article?
It all clicks and buzzes from over here! |
Re: Is there a plugin that does this?
Yes, it's just parallel compression with lots of hi boost on one of the channels. Don't know of a plug-in that does this exactly. To save voices you could send your audio track to a pair of aux tracks. You have to watch your latency with this kind of thing (depends on what plugs you're using) or you may get unpleasant phasing between the tracks, but other than that it'll give you complete control over whatever plug-ins you want to tweak for each track. Some compressors have blend controls (I can only think of a couple of hardware units that do this, and no plugs offhand) which allow you to mix the compressed and uncompressed signals, but this won't give you the ability to EQ the two signals independently.
Quite easy to do I would have thought, just bus the track to two tracks and EQ the one track and compress the other with some eq. Or ghost the audio track and eq and compress it and have the original as clean.
Pro Tools Editor, Producer, Mixer and Masterer since 1998 |
Mega plugin deals!! Slate, plugin alliance etc | crizdee | AAX Plug-ins | 3 | 02-06-2014 11:03 AM |
Automation, Plugin, write-to-all-enabled, but only for the currently targeted Plugin | joachim | Pro Tools 10 | 3 | 07-11-2012 09:48 AM |
v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1 | klyg | Artist Series | 2 | 02-29-2012 10:50 PM |
Plugin Management or Selectable Plugin Sets ?? | Lizardpoint | macOS | 2 | 04-01-2011 01:52 AM |
Vocal plugin needed to change voice, what is the best plugin | Logicdance | Digidesign Hardware & Software | 0 | 03-13-2007 04:26 AM |
