Old 05-23-2018, 05:28 AM
Meads Meads is offline
Default Re: Mac Pro mid2012 12 or 6 core for PT2018
Originally Posted by CV View Post
I'm curious as to what kind of "real world" throughput you're seeing with the Sonnect USB-C card ? Is it quick enough to run an external SSD as your OS drive ?
These are the numbers I get with a SanDisk Ultra II 960GB SSD attached to the Sonnet USB-C card.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 05-23-2018, 07:37 AM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
A new, non-pro, iMac Retina outperforms a 2009 Mac Pro in both single-core and multi-core performance benchmarks. I'm not sure that it makes sense to buy a nearly decade-old computer, however great it was in its day:
https://browser.geekbench.com/mac-benchmarks
I'd caution that Apple hasn't updated the non-pro iMac in nearly a year, so they are probably close to updating it again. I expect a new non-pro iMac to be released by the end of the year.
Old 05-23-2018, 07:50 AM
Originally Posted by SigFriedChicken View Post
A new, non-pro, iMac Retina outperforms a 2009 Mac Pro in both single-core and multi-core performance benchmarks. I'm not sure that it makes sense to buy a nearly decade-old computer, however great it was in its day.
Just ran a GB on my 2009 MacPro and I get a single core score of 2670 and a multicore of 30807. So while the iMac non pro has a higher single core performance this decade old computer still smokes it with multi core performance. Well - obviously, since it has 8 more cores than the iMac (which I assume is a quad core?).
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 05-23-2018, 08:05 AM
CV CV is offline
Thanks!
Old 05-26-2018, 01:05 PM
off the wall's Avatar
off the wall off the wall is offline
Originally Posted by SD70 View Post
Would this be a good move for PT2018? Clock speed 2.66 or 3.33...older machine but would it make sense to invest in an older machine? I see they are Avid qualified.
I’m running PT 2018.4 HDX on a 2010 MacPro 12 core. See sig for specs. It runs great. The only downside is no Thunderbolt but usb 3 seems to be gaining much better traction than Thunderbolt ever did.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
  #16
Old 01-21-2019, 04:36 PM
Howardk Howardk is offline
Mac Pro 5,1 3.46 Ghz 12 core, AMD 7970 GPU, SSD boot drive on 6Gb/sec PCIe card, 22GB RAM, MacOS 10.13.6.
Pro Tools Ultimate 2018.12. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
Hi
Do you have any issues with CPU spikes causing AAE -9171 Halts with your system? Or do you never use native VIs or Plugins?
  #17
Old 01-22-2019, 01:46 PM
Originally Posted by Howardk View Post
Hi
No issues with CPU spikes or AAE -9171.
I use Waves plug-ins quite extensively and those are all Native now.
I don't often use VIs. Mostly mixing and mastering on this rig.
  #18
Old 01-22-2019, 02:20 PM
LDS LDS is offline
Yeah, as Meads mentioned - very few people are still running the stock Apple configurations for 2009 - 2012 cMPs. I've seen those old machines go for as little as $350USD in dual CPU configurations. It is quite possible to have a machine that benchmarks between 20,000 and 31,000 for less than a $1000USD. Newer computers obviously have a bunch of upsides, but for shear bang for buck those old cMP's are still very much outshining a whole range of Apple's newer models.
Here is an old, upgraded 2009 Mac Pro for example.
http://browser.geekbench.com/geekbench3/582668
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
  #19
Old 01-22-2019, 02:36 PM
Yeah, my upgraded processor 2010 Mac Pro has Geekbench 4 Multi-core scores in the same range as top of the line 2018 MBP's and 2013 Trash Can's.
http://browser.geekbench.com/v4/cpu/7575004
Note: The 2009 Geekbench 3 scores posted above read a bit higher than Geekbench 4 scores.
  #20
Old 01-22-2019, 06:59 PM
john1192 john1192 is offline
www.ipowerresale.com
i have the 6-core .. bought from them couple years ago .. when it shipped it was at my door the next day ... !!! and it was 1699.99 then ... now with more ram, SSD drive, and 1099.00 ..
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Automation Window in PT2018 oscar_wonderboy Pro Tools 2018 5 03-27-2020 06:21 PM
Session Import on PT2018 HD always crashes electrowerks Pro Tools 2018 5 02-24-2018 08:40 PM
Man Overboard! (will PT2018 interfere with Logic?) SupreGlu Pro Tools 2018 14 02-18-2018 10:12 PM
Dissapointed with PT2018 Edit Window MarceloBcn Pro Tools 2018 7 02-06-2018 06:24 AM
PT2018.1 - Disable Tab to MIDI note end? cshaw Pro Tools 12 11 01-26-2018 05:02 PM
