Old 04-21-2021, 05:49 PM
MDekkers MDekkers is offline
Default AudioSuite menu not working
I am running Pro Tools 2018.4. My AudioSuite menu has completely stopped working. The menu still shows and you can select a function however, when you click on render there is a brief pause and then nothing. All tracks using AudioSuite (includiing other sessions) display a single line graphic and do not work. I need real help as I have several big opps coming down the pike.
Old 04-22-2021, 10:36 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: AudioSuite menu not working
Is "Use In Playlist" Blue or Gray? IIRC, it needs to be "Blue".
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
audiosuite plug at top of menu omnitarian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-31-2011 11:18 AM
Amplitube on AudioSuite menu... Jerry J. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-08-2005 04:38 AM
Audiosuite Menu won't open stoneact Digidesign Hardware & Software 4 11-17-2004 12:26 PM
Help...Audiosuite menu Non-existant??? Dj Winter Digidesign Hardware & Software 2 03-17-2002 07:18 PM
AUDIOSUITE MENU [email protected] Pro Tools TDM Systems (Mac) 1 05-04-2001 01:35 AM
