Old 10-19-2009, 11:34 AM
TheArch TheArch is offline
Default How can I add mic pre's to my mbox 2?
So for the past year I have been doing a lot of electronic stuff with my mbox 2 which worked out great with just the two mic pre's but now I want to start recording live drums and such, what can I do? (besides overheads and buying an HD rig) I need more mic pre's
Old 10-19-2009, 11:45 AM
sw rec sw rec is offline
Default Re: How can I add mic pre's to my mbox 2?
If you mean more INPUTS you'll want to seriously think about upgrading to an 003 or 003 RACK. You can PRE-mix down to 2 channels, but then you're stuck with whatever you sent in. So you don't need an HD rig...even a used 002 would give you up to 18 inputs.
Old 10-19-2009, 11:53 AM
Yes, but only 4 mic pre's I dont need all those DI inputs or Line inputs. I am trying to record a drum set. How can I do that with all those DI inputs or Line inputs?
Old 10-19-2009, 11:56 AM
003 rack-factory has 8 mic pre's
OR an 002r (they're all over Ebay these days) with a Behringer ada8000, using the adat out into the optical in on the 002r gives you 8 mic pres, in addition to the 4 on the 002.
I have one, it works.
Old 10-19-2009, 12:16 PM
Yea on the rack+ractory there is which would be great to have but money is an issue. So there is no way to could do that with an mbox correct?
Old 10-19-2009, 12:17 PM
Right, you're going to get 2 inputs on the M box. Period.
Old 10-19-2009, 12:21 PM
jmitchell1532 jmitchell1532 is offline
Even if you hooked up an external mixer with a bunch of xlrs to mic the drums, they'd still feed into the L/R of the MBox, creating 1 stereo channel.
Jon
HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!)
Old 10-19-2009, 12:23 PM
TOM@METRO's Avatar
A used 002 is well worth the money. You can find preamps very inexpensively if you don't need AD converters.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2021 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-19-2009, 12:38 PM
Ditto. A used 002 with a Behringer ADA8000 is a very cost-effective setup that would give you 12 mic preamps plus 4 line inputs(take some audio off the live PA mixer?) Whenever anyone asks about which interface they should buy, the first question I ask is; are you planning on recording drums? If the answer is YES, then Mbox is NOT a consideration. You can certainly recoup some cash by selling the Mbox to offset the expense. Used 002racks can be found for under $500 and another $200 for the ADA8000. OR, you could rent a 24 track hard disc recorder(Tascam or Alesis) for the live tracking and import the audio into Pro Tools and mix/edit with your Mbox2.
External Pre's with Mbox Pro 3 AnnexProjekt macOS 2 03-02-2013 01:12 AM
MBox 2 & its mic pre's DanielPinho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 05-06-2010 08:12 PM
Mic pre's: MBox 2 VS cheap Behringer pre's VS M-Audio Firewire 410 (Mp3 samples) DanielPinho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-18-2009 04:14 PM
Mbox & Control 24 Converters & Pre's? Archmart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-24-2004 12:46 PM
Mbox pre's vs Penta., or are they the same? platinum1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-21-2003 08:59 AM
