Pro Tools 8.0.3 Won't Load. Hangs on loading screen
just get the screen that says Pro Tools is loading, but nothing happens after that.
Windows 7 -64 bit Quad Core 9300 8 gb ram Mpowered 8.0.3 |
Re: Pro Tools 8.0.3 Won't Load. Hangs on loading screen
When I open task manager to watch it load, it gets to about 73k then drops back down to 70k, stays in Task Manager, but doesn't do anything. The UI on the desktop that says loading protools never says anything. Please help! I can post Sandra, if necessary, just haven't downloaded it on new build.
after installing did you update your M-Audio drivers and trash PT preferences?
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
since I had just installed on this machine clean, I started over again, formatted drive and began installing. What I've found is that Music Production Toolkit installed with 8.0.3 was the culprit. PT's wouldn't load at all, I would get the loading screen and then it would just stay there. when I went into the task manager it would load about 70,000+ kb and stay there. this time I installed everything one at a time and found it was MPTK. Very frustrating. I will see if I can figure out away to get it to work, but for now, I'm operating ok without it. I do create some huge projects with tons of tracks, so we'll see if it becomes a problem or not.
Pro Tools Hangs During Load | ajordon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-24-2010 07:28 PM |
pro tools hangs up at creating dae objects when loading | guitarwubs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-23-2010 07:50 PM |
Pro Tools LE 8 Hangs Up When Loading!! HELP!! | Pro Tools LE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-22-2009 06:09 PM |
New install of pro tools hangs during load up. | Minipops77 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-08-2009 01:38 PM |
Pro Tools won't load... hangs at plug-ins. | WATYF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-05-2007 03:34 PM |
