Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 10-24-2001, 11:40 AM
DeRrIcK SaSsIn DeRrIcK SaSsIn is offline
Default How do i use or setup cubase with digi 001
i juss got a new dell and although i am going to learn protools
my proficiency right now is cubase and its harder to set up
i had tried taking out my sound blaster
pro tools works and so does sound forge
does any one out there know for sure if cubase for windows works with the digi 001
HELLPP!
hollaaaaaaaaa
Old 10-24-2001, 02:21 PM
Raziel Raziel is offline
Default Re: How do i use or setup cubase with digi 001
You may want to do a search, in the Digi 001
for Windows forum. You're bound to find some
info. on this. I do hear the latency with Cubase & PT is substantial.
Old 10-24-2001, 03:43 PM
peteri peteri is offline
Can't really help from personal experience - but did a search and found the following article:
http://duc. digidesign.com/cgi-bin/ubbcgi/ultimatebb.cgi?ubb=get_topic&f=32&t=000899
Although it's a year old (nearly) I can't believe anything's changed. Doesn't surprise me as Steinberg stopped supporting DAE a few years ago (well maybe 18months anyway).
I should probably qualify that the Digi response may seem a bit strange saying contact Steinberg to get them to provide the drivers. I think this stems from Logic and Digital Performer both directly support Digidesign hardware. Whereas a little while back Steinberg said if you want your hardware to work with Cubase you have to provide ASIO drivers. As this is hardly Digi's primary market, it's not really a shock they haven't. Plus you've got to imagine they must be pretty mad at Steinberg for suddenly dropping support.
Time to learn Pro-tools then!
Good luck
Pete
Old 10-24-2001, 05:13 PM
lwilliam lwilliam is offline
I believe the Mac ASIO drivers for Cubase are about 2 years old and only run ASIO version 1. I'm not sure they will even run on Cubase 5.0.
I don't believe there are ANY ASIO Digi drivers for the Windows version of Cubase.
I believe Steinberg calls these "ASIODirectIO" drivers. You might try a search on their site or an email to them.
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
CUBASE SX 2 on DIGI 001 depeche_cerati 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-20-2005 07:03 AM
MBox CoreAudio Setup and Cubase SX BPrent General Discussion 0 10-26-2003 10:47 AM
How do i use or setup cubase with digi 001 DeRrIcK SaSsIn MIDI 0 10-24-2001 11:42 AM
Setup problems with Cubase and PT Alex T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-08-2000 08:38 PM
Using Cubase with Digi 001 Mrgeoff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-23-2000 11:16 AM
