Old 05-08-2012, 06:52 AM
alooker alooker is offline
Default Plug in favourites menu
Hi all,
Having some trouble with the plug ins I've selected as favourites not showing up after opening a session from a client. Their version is 9.1 I believe, we're using 8.1 on a hd5 rig. Any idea of how to get it back without going through the rigmarole of searching through a big list of plugs?!
Thanks,
A
Old 05-08-2012, 07:22 AM
Drew Mazurek's Avatar
Default Re: Plug in favourites menu
How many were there? It probably took longer to create this acount and post this than to Command-Select to re-establish your favs!!
www.drewmazurek.com
Old 05-08-2012, 08:08 AM
I'd rather understand the problem so it doesn't happen again. I have around 11-12 on TDM and 5-6 RTAS and searching through the plug in list is something I don't want to do every time I get sent a session that 'magically' removes my favourites list.
Old 05-08-2012, 10:36 AM
If I remember correctly, these are stored with your Prefs. So, it you make a backup copy of your prefs, you should be able to restore them whenever you need to.
http://web.mac.com/jcdeshaies/applic...se_Helper.html
www.drewmazurek.com
Plug Ins I have uninstalled still show in Plug Ins menu Robusto Windows 4 12-28-2013 01:43 PM
Favourites in PT Drop Menu ThisIsSick Tips & Tricks 1 09-26-2009 05:12 AM
Menu BUG...Menu FREEZES...Menu LOCKS UP...Restart Pro Tools! a2zproductions Pro Tools TDM Systems (Mac) 16 05-08-2008 08:30 AM
PT LE 7.1.1 & Plug in Menu Awesome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-12-2006 04:22 PM
Plug In Pop up menu peterrichter Tips & Tricks 0 01-30-2000 01:03 PM
