Old 12-12-2011, 09:04 AM
Chingy Chingy is offline
Default Demo Songs / Sessions for PT10
I noticed in the PT10 trial download (+ the extended downloaded) there wasn't any demo songs / sessions. I believe PT8 and PT9 came with some demo songs? Is there a way to download some demo sessions? Or, since I don't have PT9, a way to get the demos from PT9?
Thanks!
Old 12-12-2011, 12:54 PM
panamajack's Avatar
panamajack panamajack is offline
Default Re: Demo Songs / Sessions for PT10
There is a demo song on the PT10 backup DVD. You can purchase the backup DVD online for $15. The DVD also has the pdf files.
Old 12-12-2011, 01:17 PM
matthias.matthias matthias.matthias is offline
Wink Re: Demo Songs / Sessions for PT10
No need to order the backup DVD. The pdfs and the demo session are included with the download version as well. They are in a folder called "Additional Files" located within the downloaded archive.
The huge file size of the installer has to be good for something.
P.S.: The above is definitively true for the bought windows version, but my guess is, it's the same for Mac and the demo as well.
FR: MIDI Playlist View
Old 12-13-2011, 10:08 AM
Thanks - I'm seeing a peak of 37% CPU usage on the demo song. Does that sound good / bad / average for an 8-core Mac Pro? 100% of the timeline is cached.
I made some of the AVID suggested optimizations as well - didn't really seem to do all that much. How effective are things like turning off WiFi, Bluetooth, and Spotlight Indexing?
Old 12-14-2011, 07:59 AM
Bump. Any thoughts on the demo track performance?
Old 12-14-2011, 08:29 AM
avatar9000 avatar9000 is offline
I tripped out when I loaded up the demo song and the CPU (native) was hovering around 68-72% at idle. I'm running a 2.4 Core Duo with 8GB RAM, Mac OS 10.6.8. I also got a CPU overload error about half way through playing the session. I was concerned.
I created a new session, and created 20 tracks at a time, each time putting ChannleStrip on everyone. I got up to 200 mono tracks, each with ChannelStrip, and the cpu hovered around 80%. For kicks and grins, I added SansAmp to each channel. That brought it to its knees of course.
I started removing tracks and was able to have around 120 tracks, each with ChannelStrip and SansAmp. CPU usage was again around78-80%. I'm happy with that for an "LE" native system. This was with a buffer setting of 1024 since all I do on this rig is mix and master. Start reducing the buffer size, and system performance starts to take a hit naturally.
Those are my findings since having it installed 12 hours ago.
Old 12-14-2011, 02:10 PM
MarkH MarkH is offline
I have a MBP 2.93ghz Core 2 Duo (full specs in my signature) and the PT10 demo session averages around 65-67% CPU utilization. I have CPTK so I can take advantage of the cached timeline and I do not receive any errors during playback. If I disable caching the CPU will move up and down more and I'll get a playback error.
With the PT9 demo session (The Legion) I would average around 35% CPU utilization when running in PT9. I haven't tested The Legion in PT10.
Old 12-14-2011, 11:32 PM
What was your buffer setting at and interface? Mine wa at 128 with an Mbox 3 Pro.
Any other Mac Pro or Mbox 3 Pro users try this?
Old 12-15-2011, 12:56 AM
browniespeaks browniespeaks is offline
On my home machine win7 64 i3-550 6GB RAM and mbox mini (3g) Command 8. I'm at 30% idle and 35%peak CPU (native), CPU Clip 1-4% and Disk 13% Thats at a 512 buffer. No change on stats at lower buffer sizes. Running nice at 128 now.
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 12-15-2011, 08:34 AM
For Audrye Sessions-Turn Me Off my buffer was at 512. If I change it to 128 I see an average of 75% but the peak shoots much higher and I will get some pops and clicks happening at periodic intervals. If I set it to 256 the average is 69-70% and the playback is smooth. I attribute this to the timeline caching because without it I get CPU errors even at 512.
PT10 Crashes only on one group of songs! kiddakota macOS 7 06-10-2012 10:26 PM
Bought PT10, do I remove the PT10 demo? esperanto macOS 2 04-18-2012 12:01 PM
missing some files on songs since installing PT10 [email protected] macOS 7 03-01-2012 08:19 AM
Sessions VS Songs distratman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-16-2005 10:59 AM
separate songs on long sessions? hendymail Tips & Tricks 5 01-19-2005 12:03 AM
