Old 12-28-2010, 04:16 PM
jsmooth226 jsmooth226 is offline
Default Having A big issue with bounce 2 disk ...
this will not work for me no matter what the buffer size is ... is there some solution for this problem ... Running Mac Pro 3.0 Quad with 6gig ram system drive 1tb western digital black 32mb cache ...any help with this issue would be appreciated!!!
Old 12-28-2010, 04:18 PM
philip888's Avatar
philip888 philip888 is offline
Default Re: Having A big issue with bounce 2 disk ...
What is doing?
Has it worked before?
Do you have proper permissions set for the drive you wish to bounce the audio to?
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
Old 12-28-2010, 04:21 PM
cpu overload error 6101... says to increase buffer or remove plugins ... but will happen with no plugins and 1 track of audio ... worked before upgrading to pt9
Old 12-28-2010, 09:16 PM
AxeDye AxeDye is offline
can you record the stereo master through a stereo bus onto a new stereo track and handle any conversions you may need with another software. I have only heard of bounce to disk issues with the pirated version of PT9
Old 12-29-2010, 02:00 AM
crizdee's Avatar
crizdee crizdee is offline
When you upgraded to 9 did you trash your prefs?
Anyway this would be the first thing to try now, use this app below...
http://duc.avid.com/showthread.php?t=190122
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-29-2010, 06:22 AM
GORILLA GORILLA is offline
This is getting weird as I had the same problem. I've been using Pro Tools since the 001 days and never never never had such problems as I did with PT9! I couldn't bounce nothing either, not even the demo session WITH ALL PLUGINS removed! It would start the bounce for about 1 second, then the 6101 buffer error popped up! Mac Pro 2x2.66Ghz dual core, 8gigs of ram and same hard drives. 2 dedicated audio only drives, 1 samples only drive. My main system drive has 64mb cache. I thought maybe it's just my system but I'm starting to see these threads now, so it's not just me.
Crizdee next time I get PT9 here I'm going to try that plug-in as I did have PTLE 7.3 on this computer.
Good Luck Jsmooth if you figure it out puh-lease post how ya fixed it.
METAL LABS
Old 12-30-2010, 12:16 AM
that little program did the trick .... Thank you very much for the assistance!!!
Bounce to disk issue jonslaten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-26-2009 08:48 AM
Bounce to disk issue dafatboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-04-2009 04:34 PM
Serious Bounce to Disk Issue TreeDaddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-29-2008 08:44 PM
Bounce To Disk Issue blast0rama 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-20-2007 11:23 AM
Mp3 Bounce to disk issue Soundworks UK Pro Tools TDM Systems (Mac) 0 07-04-2002 12:28 AM
