Old 09-22-2008, 03:43 PM
jkess jkess is offline
Default Core Audio not working with other apps
I recently upgraded to 10.5.4, and pro tools to 7.4.2 and Core audio won't engage when quick time or a web browser opens, limiting the playback of anything other than Pro Tools to the computer speaker. What is screwed up here. Did not find any prefs to default coreaudio as the audio out. Whats Up? What simple thing am i missing?
Thanks mucho,
josh
Old 09-22-2008, 04:06 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Core Audio not working with other apps
Thanks mucho,
josh
Have you checked the AMS setup! is it set to digidesign coreaudio?
Also you could try trashing the prefs for the AMS setup. user/library/prefs
Producer, Engineer,
www.ukmastering.com
Old 09-22-2008, 07:54 PM
elicious elicious is offline
if you do a search, you'll find many related threads in many forums talking about this.
known issue, only workaround is to open sys prefs in apple, go to sound pane and toggle between line out and digi output.
or better, if you have optical ins and outs on your system, connect your interface out to your optical in on your mac; under hardware setup create a path for the optical in, then make an aux trak in tools,
assign the proper input and you can have your apps and eat them, too
b.o.l.
e
ihatetyping
Old 09-23-2008, 11:58 AM
Well that is the problem. Digidesign is not showing up as an option in the Audio Midi Set-up or in the Sound Pref window. For some reason, that part of the software did not load. Is there a download for this?
Thanks again,
josh
Old 09-30-2008, 05:49 PM
*bump*
Old 09-30-2008, 06:38 PM
DigiTechSupt's Avatar
It's part of the Pro Tools installer. Run the 7.4.2 installer again and check 'Core Audio' on the Custom Install page...
Avid Audio Tech Support
Support FAQ
Old 10-01-2008, 01:43 PM
Will do it. Thanks very much for chiming in.
josh
Core Audio Apps have a delay michael c Pro Tools TDM Systems (Mac) 4 02-02-2010 09:28 PM
No audio from Apple Apps. Core Audio problem? Armando Pro Tools TDM Systems (Mac) 10 10-23-2006 06:03 AM
core audio/3rd party apps codfish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-16-2005 03:46 PM
Can two apps use Core Audio at the same time? willson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-01-2003 07:58 AM
Core Audio (Limiting which Apps can use it.) carouzal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-19-2003 08:49 PM
