Old 06-24-2005, 01:22 PM
Jake Jackson Jake Jackson is offline
Default Playlist bug 6.9
Has anyone else using playlists come across this bug?
If you have a large number of tracks in a group, so that they are not all visible on the screen, and then change playlists, some of the tracks are ignored. Let me give an example.
Say you have 48 audio tracks, seeing 1-24 in the screen, depending on zoom, track size etc, when you change playlist from tk.3 to tk.2, down the bottom, track 48 tk.3 will be on track 45 tk.3, 47 on 44, 46 on 42 etc with the 48 tk.2 still on 48 tk.2.
You can get around this bug by having the bottom of the tracks in the screen when you change, eg 36-48, and then it changes properly.
I haven't had a chance to check to see if this is fixed with a cs update, and also it appears to be a bit random as well, but it has happened on at least 2 of our rigs.
This would be a great one to fix.
Cheers
Jake
Old 06-25-2005, 08:52 AM
Danny Caccavo Danny Caccavo is offline
Default Re: Playlist bug 6.9
I can't seem to reproduce this. Can you provide a recipe from scratch to reproduce this? (i.e. start with a new session, make 48 tracks, etc). Just in case, please save a copy of the session file, in case we need it.
Just to confirm - it's all fine when you scroll to the bottom and switch playlists?
Did the session origininate in Pro Tools 6.9?
Thanks!
Danny Caccavo
Digidesign
Old 06-27-2005, 02:05 AM
Thanks Danny,
I don't have a tools system in front of me to check some of the things you have asked, but will try to replicate later, but to answer your other questions....
It is fine when you are at the bottom of the selected tracks, and change playlists.
But, i think that both times we have seen this, the sessions were more than likely made in 6.4.
Regards
Jake
Old 06-27-2005, 09:20 AM
DigiTechSupt's Avatar
Jake - You may also want to trash prefs and databases, as this could be a corrupt preference file causing the problem.
Avid Audio Tech Support
Support FAQ
Old 06-27-2005, 10:34 AM
protooleriate protooleriate is offline
there was, and still is, a bug that arrived in 6.7 whch did this when there were tracks that were hidden, i think digi know about it, i know i have told them about it and so have other mutual friends of ours
Old 06-27-2005, 10:47 AM
Thanks Digi and Protooleriate,
I had tracks hidden when i had this problem, and also the other people at our studio would have had some hidden also, when they had the problem.
I assume it is unlikely that 2 different machines had corrupt database files at the same time, and because Protooleriate mentions this is an old bug, and we didn't use 6.7 here, so wouldn't have come accross it until we started using 6.9.
Ho Hum!
Regards
Jake
A way to create a new playlist when re-recording over playlist section? jschmidtiii macOS 2 08-13-2013 02:28 AM
Playlist Mac88s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-03-2010 06:35 AM
Playlist bug in 8.0 jhayward 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-21-2009 12:33 PM
PT8 Playlist bug MeBangKeys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-28-2009 11:44 PM
No Playlist trsaudio Digidesign Hardware & Software 6 10-23-1998 11:30 AM
