Old 03-28-2005, 11:36 AM
GregJ GregJ is offline
Default VST2RTAS problem
Help! Seemingly out of nowhere, ProTools 6.4 will not recognize my UAD-1 plugins via the wrapper. I have tried reinstalling software and different versions of the wrapper, but no luck. I have tried the special UA-only wrapper and the full retail version of the wrapper. Plus, earlier this morning I bought the Plate 140 reverb plugin and ProTools says it is inactive because it can't be found in the plugins folder.
Where would you start?
Thanks,
GregJ
Old 03-28-2005, 11:52 AM
Roy Howell Roy Howell is offline
Default Re: VST2RTAS problem
Hi Greg,
I would check your Fxpansion/vst plugins folder to make sure the UAD-1.dll file is there. If not, do a simple Search for the UAD-1.dll(and any others that are missing). Once found, copy and paste it in the Fxpansion/vst plugins folder. Be sure to have the VST/RTAS/Configure detect them before opening PT.
Hope that gets it.
-Roy
rh music
Old 03-28-2005, 12:36 PM
Roy,
Thanks for your quick reply, but no luck with the fix. I don't know what else to try....
Anyone done battle with this before?
GregJ
Old 03-28-2005, 01:05 PM
SaxMan2150's Avatar
SaxMan2150 SaxMan2150 is offline
First , which version of the UAD SW are you running?
The UAD plugs should be installed in in their own folder(Powered Plugins) in your default VST folder on your HDD. For most it c:\program Files\steinberg\VST plugins.
Copy the powered plugins folder to Teh Fxpansion folder C:\program files\fxpansion\vstplugins folder.
On the VST to RTAS configuration dialog box uncheck
search globally for VST's & then only VST's in the
C:\program files\fxpansion\vstplugins will be wrapped.
Make sure you download the Reg file from myuaudio
for your recent purchase.
Hope this helps.
MacBook Pro, 2.6GHz I7 Quad, 8GB, Thunderbolt Display, Apollo Twin Duo, UAD Quad Thunderbolt Satellite, OSX 10.9, Pro Tools 12.4
Old 03-28-2005, 03:16 PM
Well, I tried all the above mentioned suggestions. No luck with any of it.
I did figure out a workaround, though. I took out one of the 2 UAD-1 cards and rescanned (globally) for vst plugs to convert. It worked! Then I put the other card in by itself and redid the scan - it worked again.
Apparently, the wrapper gets hung up when both cards are in at the same time and I try to detect VST plugins.
Any ideas as to why this may be?
Thanks for the replies,
GregJ
MrRay and Vst2Rtas tromostheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-18-2008 03:20 AM
VST2RTAS General... CoopShow Tips & Tricks 5 07-27-2006 10:14 AM
M-Tron problem with the VST2RTAS wrapper Steve2000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-12-2004 03:54 PM
uninstalling VST2RTAS Help Me Please mersisblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-26-2004 01:50 PM
What's this new Vst2Rtas wrapper about? K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-22-2004 10:45 AM
