Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 12-30-2010, 08:26 AM
TB12 TB12 is offline
Default CPU Overload 6101
Hello
I am having the same problems as a few of you, thought I'd better start a new thread to increase the chances of DIGI looking at this.
I am getting constant 6101 errors
My set up is this:
Macbook Pro 2.8 GHz, 4gb mem,
OSX 10.6.5
PT M powered 8.0.4 cs2
Mackie onyx 1620i using latest firmware (1.05.00129) connected via FW800 port to FW400
V1.0.4 Mackie Universal Driver
iOmega HDD1H4-2 connected via FW400 PCI card
I've tried all the general set up stuff, I've deleted the launch deamon and system pref for elevenrack.
I was running with a projectmix i/o which was running intermittently, but it packed in so had to switch to the onyx.
I got Reaper running fine, but cannot use BFD for some reason! I am hating computer recording right now - everything seems so flaky!
I will try and post the log files....
Old 12-30-2010, 08:37 AM
Default Re: CPU Overload 6101
Error suppression is on, by the way....
Old 12-30-2010, 09:04 AM
http://www.mediafire.com/?z9bbnjd44qvckdc
theses are the latest log files I could find
Old 01-02-2011, 10:29 AM
Turnin error suppression off and upping the H/w buffer seems to have done the trick - now got mixdown problems - the mix is coming out slow - AARRRRRRRGGGGGHHHHHHHH. will start a new post...
CPU Overload -6101 wiggity5050 Pro Tools 10 4 01-04-2014 04:10 PM
6101 CPU Overload Jeroen.Kox Pro Tools 10 4 12-17-2013 03:27 PM
CPU Overload (6101) foxdog175 macOS 17 10-26-2012 10:18 AM
(-6101) CPU Overload Error CujoAC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 29 07-04-2008 11:20 AM
-6101 CPU overload bad_ben 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-26-2007 04:53 PM
