Rename inputs and outputs??
Did some searching here but didn't find the answer ...
Is there a way to create custom names for the i/o's? By default all the buses are called "bus 1-2, 3-4" etc. Is there a way to change how these show up in the output menus? In Sonar, when I would set up and name a new bus (e.g. reverb, drum submix) that name would show up in the list of options when assigning an aux send or bussing a channel. Any way to make this happen in PTLE? I'm having trouble remembering if my reverb is bus 3-4 or 5-6 ... Thanks, AG |
Re: Rename inputs and outputs??
Hi, select setup->I/O setup from the menu in PT. double click on the names of I/O channels and type in a new name. RTFM p.67 chapter 7 regs
last: PT11.3.1 |
PT 8.1 Rename Outputs? | nortstudio | Pro Tools TDM Systems (Mac) | 3 | 11-23-2011 12:43 PM |
MIDI I/O rename Port Outputs???? | alx002 | MIDI | 4 | 07-27-2011 06:38 PM |
Inputs and Outputs | PUMASALAD | macOS | 2 | 04-28-2011 02:47 AM |
Protools 7 : rename midi outputs / reorganise plugs. | ju-hill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-09-2010 12:35 AM |
not getting all my inputs and outputs??? | digifriend | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-04-2009 03:23 PM |
