Error Message: cannot parse audio file
Hi Guys
I get this error message after I double click on a protools session file to open it after I moved the file from it's original hard drive onto a new hard drive. Cant get it to play from the new hard drive. Thanks for any ideas. |
Re: Error Message: cannot parse audio file
Is your new drive formatted to Fat32 by chance?
Sign up for all things....AWESOME! Kris May the music move you |
I've solved this issue in the past by trashing preferences/databases. Go on all your drives, delete all the "Digidesign Database" folders. Then go into Program Files\Digidesign\Pro Tools and delete the Databases folder there. I forget if I had to trash my DAE Prefs folder in Common Files as well, but I don't believe so. Hope this solves it for you!
Hi All
Trashing prefs/databases does not seem to fix this issue, can anyone offer any alternative ideas or solutions? |
Hi Guys
I get this error message after I double click on a protools session file to open it after I moved the file from it's original hard drive onto a new hard drive. Sometimes the file will play but the edit/mix windows appear broken up which renders the GUI totally unusable. Thanks for any ideas. |
OK I hope this will help you help me:
SiSoftware Sandra Computer Model : Gigabyte 965P-S3 Workgroup : WORKGROUP Host Name : RYAN User : user Processor Model : Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz Speed : 2.67GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Mainboard : Gigabyte 965P-S3 BIOS : Award (Phoenix) F9 04/26/2007 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.5GB DIMM DDR2 Chipset Model : Giga-Byte P965/G965 Memory Controller Hub Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 4GB DIMM DDR2 Memory Bus Speed : 2x 416MHz (832MHz) Memory Module(s) Memory Module : Kingmax KLDE88F-B8KB5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Memory Module : Kingmax KLDE88F-B8KB5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Video System Video Adapter : NVIDIA GeForce 8600 GT (32 SM4.0 1.35GHz, 256MB DDR3 2x720MHz, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 8600 GT (32 SM4.0 1.35GHz, 256MB DDR3 2x720MHz, PCIe 1.00 x16) Storage Devices ST3750640AS (750.2GB, SATA300, 3.5", NCQ, 16MB Cache) : 699GB (C:) (D:) (E:) Hitachi HDT721016SLA380 (160GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) : 149GB (G:) (H:) Ð÷IÇ. (SATA4800, DVD+-RW, CD-RW, NCQ, 26MB Cache, 4GB Flash) : 2GB (F:) Logical Storage Devices Hard Disk (C:) : 311GB (NTFS) @ ST3750640AS (750.2GB, SATA300, 3.5", NCQ, 16MB Cache) Graphics (D:) : 50GB (NTFS) @ ST3750640AS (750.2GB, SATA300, 3.5", NCQ, 16MB Cache) AUDIO A (E:) : 337GB (NTFS) @ ST3750640AS (750.2GB, SATA300, 3.5", NCQ, 16MB Cache) AUDIO B (G:) : 20GB (NTFS) @ Hitachi HDT721016SLA380 (160GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) BACKUP (H:) : 130GB (NTFS) @ Hitachi HDT721016SLA380 (160GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) LRMCFRE_EN_DVD (F:) : 2GB (UDF) @ LITE-ON DVDRW LH-20A1H (SCSI, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : Giga-Byte 82801HB/HR (ICH8/R) LPC Interface Controller LPC Legacy Controller 1 : ITE IT8718F Audio Device : Giga-Byte 82801H (ICH8) HD Audio Controller Audio Device : Creative Labs SB1040 Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Giga-Byte 82801H (ICH8) 4 port SATA Controller Disk Controller : Giga-Byte 82801H (ICH8) 2 port SATA Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte 82801H (ICH8) USB UHCI #4 USB Controller 2 : Giga-Byte 82801H (ICH8) USB UHCI #5 USB Controller 3 : Giga-Byte 82801H (ICH8) USB2 EHCI #2 USB Controller 4 : Giga-Byte 82801H (ICH8) USB UHCI #1 USB Controller 5 : Giga-Byte 82801H (ICH8) USB UHCI #2 USB Controller 6 : Giga-Byte 82801H (ICH8) USB UHCI #3 USB Controller 7 : Giga-Byte 82801H (ICH8) USB2 EHCI #1 SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : Journal Note Writer Driver (600x600, Colour) Printer : Canon MP630 series Printer (USB, Colour) Printer : Adobe PDF Converter (4000x4000, Colour) Network Services Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows Vista Home 6.00.6000 Platform Compliance : x86 Windows Experience Index Current System : 5.5 |
Have you told us what interface and PT version you are running?
If the 7mb cache Hitachi is the new audio drive, it may not be enough in terms of cache. The others appear to be partitions on the system drive, and that won't work properly for you.
Thanks Tom I am running 7.4 on an Mbox2
can the Hitachi Cache be set to a bigger size? What size does the cache need to be? |
Hi Tom
What is the optimum (or at least working) set up for recording/playback and backup with hard disks? Many Thanks for your help |
PT 10 "Unable to parse audio file" error | matt-o- | Pro Tools 10 | 3 | 04-07-2014 10:19 AM |
"unable to parse audio file" and "OSStatus Error -208" ! | reichman | Post - Surround - Video | 2 | 03-22-2010 04:46 AM |
Error message: Cannot parse audio file | T-Diddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-09-2010 03:31 PM |
Urgent! Pro Tools error: Could not parse audio file | bastin | Pro Tools TDM Systems (Mac) | 2 | 10-28-2008 08:03 AM |
unable to parse audio file | Studio Studio | Pro Tools TDM Systems (Mac) | 1 | 06-21-2006 08:13 AM |
