Changing note values while changing meter - I'm stumped
I received a midi file in 4/4 with eighth notes quantized as triplets. I want to change it to 12/8 with the eighth notes quantized as eighth notes. I want the quarter note click in the old meter to equal the dotted quarter click in the new meter - the tempo should remain the same. I'm totally stumped. No matter what I do the absolute note values remain the same - the eighth notes are quantized as eighth-note triplets in the new meter. I can't make them conform to 12/8. Can anyone help?
Thanks! |
Re: Changing note values while changing meter - I'm stumped
You need to set your tracks to sample ref before you do this. Tick ref always refers to tempos in 1/4 notes, so when you try change it to dotted quarter tempo it's changing the note lengths. I know it's a bit stupid musically speaking but it's just one of those quirks. Try this:
1. Set all your tracks to sample ref 2. Set your meter to 12/8 with click to dotted 1/4s 3. Set your master tempo to dotted 1/4 resolution 4. Change your MIDI tracks back to tick ref Now they should be on the 1/8s as expected. To be honest I've largely given up using dotted 1/4 click resolution in triple time for this reason, I just change the meter, leave the master tempo in 1/4s (multiply by 2/3s if you need to work it out - 120bpm dotted = 80bpm 1/4s) and program clicks manually with MIDI loops. Melodyne and some other 3rd party apps won't work well with dotted clicks either. |
Thank you very much, suicune. I stumbled into that solution very late last night - exactly as you describe. This was a midi file that was sent to me by my kid. She needed to transfer it to Sibelius for score and parts printing, but she started sequencing in 4/4. The great lesson is to start in 12/8 if you want to wind up 12/8.
Thanks again, Seth |
Thanks. |
Well, I found another way to accomplish this. I used the Time Compression/Expansion tool (TCE) to stretch everything by a factor of 1.333 and then changed the meter. (No need to change to sample based time.)
S5-MC changing meter refs from -20 to -18 | Steven1145 | System 5 | 2 | 10-05-2010 01:05 AM |
values changing on L3 | bbob | Pro Tools TDM Systems (Mac) | 10 | 06-02-2007 07:35 PM |
Hear Note While Changing Velocity | relaxo | MIDI | 5 | 11-16-2005 10:27 AM |
Changing Meter | digijohn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-27-2005 08:48 PM |
Changing Grid Note value on 15" Monitor... | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-21-2001 12:32 AM |
