Old 12-26-2001, 05:06 PM
Groovy C Groovy C is offline
Default "Error Code -6031 was returned by the Direct I/O driver."
I've had nothing but probs with my digi 001. I keep getting the following error code when I want to record:
http://www.groovychicken.f2s.com/direct_io.jpg
Here's the Hardware Setup for Direct I/O in LAP 4.8.1:
http://www.groovychicken.f2s.com/digi_hardware.jpg
What am I doing wrong?
My Setup:
Mac G4/400 AGP
320 MB
Mac OS 9.2.2
digi 001
LAP 4.8.1
emagic mt4
in Extensions folder:
Digidesign® Direct I/O 5.1.1
Digidesign® DSP Manager 1.1.1
DigiSystem™ INIT 5.1.1
ANY help would be appriciated [img]images/icons/smile.gif[/img]
regards,
GC
Old 12-27-2001, 07:18 AM
DigiTechSupt's Avatar
Default Re: "Error Code -6031 was returned by the Direct I/O driver."
I have seen this error posted as the result of the following:
1-Possible buffer size problem in Logic:
- If the I/O Buffer size is really low (from the screen shot, yours is set to .125) then increase it, quit logic and reopen the song.
2-Potential conflice with the Digi001 OMS driver. Remove the Digi 001 OMS driver from the OMS Folder. The OMS Folder is in the system folder.
Brent
Avid Audio Tech Support
Support FAQ
Old 12-27-2001, 09:02 AM
I didn't have this problem until I did an update to Mac OS 9.1. I've always had the buffer set to .125. There never was any problem. I've even tried giving I/O more buffer but nothing. And I removed the OMS stuff a long time ago.
Help!
Old 12-28-2001, 08:32 AM
We have not yet qualified Mac OS 9.2.2, so I am not sure if that effects Direct I/O operation at all. Check with Emagic regarding Logic Audio compatibility with Mac OS 9.2.2.
-Does the -6031 error persist if you remove the MT4 from the system?
If you haven't already done so, trash the DigiSetup File from the System Folder>Preferences folder. Empty the Trash and restart the Mac.
Brent
Support FAQ
PLEASE HELP! PT8.0 LE gives "Initialization Error Code: -7" and will not launch... tightist2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-07-2013 11:16 PM
SOLUTION - PT 8 "Digidesign Audio Driver Error -2147213312 " StavrosSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-03-2009 06:17 AM
Error code -9035 returned by DAE driver richswit Pro Tools TDM Systems (Mac) 5 09-21-2007 02:14 PM
Error code 28773 returned by the core audio driver p2h 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-23-2004 10:50 AM
error code 6031 using direct i/o in logic graphite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-29-2001 07:08 PM
