Old 06-02-2006, 04:59 AM
themindlab themindlab is offline
Default Dell Inspiron 6400 and Mbox2
Anyone having trouble with Inspiron laptops ?
I have an Inspiron 6400 Dual core 1.66 Mhz and an Mbox 2 fresh out of the box and as soon as i installed pro tools 7 I got the following error:
"the operating system interrupts held off for too long" (-9094)
After formatting and installing Win xp SP2 the situation improved, but as soon as I open a project that requires more than 20% of CPU the error is there again. This thing is not letting me work !! Should I go back on a mbox, buy a mac or switch to another software like nuendo ??
I would appreciate some suggestions...even if I'm posting this to find out if there are other Inspiron users that share my problem. Digidesign might be able to solve it...Dell sells a lot of laptops !
Old 06-02-2006, 05:08 AM
spkguitar's Avatar
Default Re: Dell Inspiron 6400 and Mbox2
This is usually the result of hard drive mis-configuration. What hard drive are you using for your sessions? How do you have it connected to the Dell? Are you following all of the compatibility requirements?
There are also many recommendations in the General Troubleshooting thread that may help.
Old 06-02-2006, 04:40 PM
Thanks for the interest !
Well, I've tried the general trouble shooting but nothing improved.
When I load a project the performance meter in protool is to about 25% while the windows task manager is stuck at 100%...
I disabled all the things recommended by the digidesign troubleshooting in the BIOS and I expecially disabled the speed-stepping. I also set pro tools to work with one processor...still, task manager indicates a processor stuck at 100%...
My hard drive is a Lacie 200GB connected via USB...
Hmm...really don't know what to do...it's definately protools sending Win Xp "crazy" but can't think were the problem is...
Old 06-02-2006, 06:08 PM
spkguitar's Avatar
USB drives are not supported. Firewire drives with the Oxford 911 chipset are required for external drives with Pro Tools.
Also, not to be a jerk, but one of the suggestions in the General Troubleshooting thread is
Note: To enable other users to help you, please include all of your system details when posting an issue to the DUC; Pro Tools hardware, Pro Tools software version, CPU, OS version, Motherboard make/model, chipset, amount of RAM, type of hard drives used, etc.
- SiSoftware's Sandra Lite application can be used to post your full system profile:
www.sisoftware.net
Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions.
Running a System Summary from Sandra will make easier for users here to make recommendations, as they will know exactly what you have.
Old 06-03-2006, 11:52 AM
Hi, my thead took another direction as I initially I was hoping to find someone with my same computer (these are dell best sold laptops...) and with the same problem so to solve it quickly.
However, I've run the system analisys, this is the result:
Processor >
Model: Genuine Intel(R) CPU T2300 @
1.66GHz
Speed: 1.66GHz
Cores per Processor: 1 Unit(s)
Threads per Core: 1 Unit(s)
Type: Mobile
Internal Data Cache: 32kB Synchronous, Write-Thru, 8-way set, 64
byte line size
L2 On-board Cache: 2MB ECC Synchronous, ATC, 8-way set, 64 byte
line size
< Mainboard >
Bus(es): ISA X-Bus PCI PCIe USB i2c/SMBus
MP Support: No
MP APIC: No
System BIOS: AT/AT COMPATIBLE DELL - 27d60309
Mainboard: Dell Inc. 0KD882
Total Memory: 503MB DDR2-SDRAM
< Chipset 1 >
Model: Dell Computer Corp Mobile Memory Controller
Hub
Front Side Bus Speed: 4x 277MHz (1108MHz data rate)
Total Memory: 512MB DDR2-SDRAM
Shared Memory: 8MB
Memory Bus Speed: 4x 221MHz (884MHz data rate)
< Video System >
Monitor/Panel: Plug and Play Monitor
Adapter: Mobile Intel(R) 945GM Express Chipset Family
< Physical Storage Devices >
Hard Disk: FUJITSU MHV2100BH (92GB)
CD-ROM/DVD: SONY DVD+-RW DW-Q58A (CD 24X Rd, 24X Wr) (DVD
3X Rd, 3X Wr)
< Logical Storage Devices >
Hard Disk (C:): 49GB (14GB, 29% Free Space) (NTFS)
Pro Tools LE (D:): 479MB (CDFS)
< Peripherals >
USB Controller/Hub: Intel(R) 82801G (ICH7 Family) USB Universal
Host Controller - 27C8
Host Controller - 27C9
Host Controller - 27CA
Host Controller - 27CB
USB Controller/Hub: Intel(R) 82801G (ICH7 Family) USB2 Enhanced
Host Controller - 27CC
USB Controller/Hub: USB Root Hub
Keyboard: Standard 101/102-Key or Microsoft Natural PS/
2 Keyboard
Mouse: Synaptics PS/2 Port Pointing Device
< Printers and Faxes >
Model: Microsoft Office Document Image Writer
Model: HP LaserJet 1020
< Power Management >
AC Line Status: Off-Line
Battery No 1: 33%
< Operating System(s) >
Windows System: Microsoft Windows XP/2002 Professional
5.01.2600 (Service Pack 2)
< Network Services >
Adapter: Intel(R) PRO/Wireless 3945ABG Network
Connection
< Performance Tips >
Notice 5901: CD 1x= 150kB/s; Exercise caution when
comparing measured versus published ratings.
Notice 5902: DVD 1x= 11.08Mbps Exercise caution when
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
Processor Multi-Media >>>
< Benchmark Results >
Integer x8 iSSE2: 7706 it/s
Float x4 iSSE2: 10454 it/s
Results Interpretation: Higher index values are better.
< Performance Test Status >
Run ID: DAN-2444B21250E on 03 June 2006 at 19:03:46
NUMA Support: No
SMP Test: No
Total Test Threads: 1
Multi-Core Test: No
SMT Test: No
Dynamic MP/MT Load Balance: No
Processor Affinity: P0C0T0
System Timer: 3.6MHz
Rendered Image Size: 640x480
< Processor >
1.66GHz
Speed: 1.66GHz
Type: Mobile
line size
< Features >
(W)MMX Technology: Yes
SSE Technology: Yes
SSE2 Technology: Yes
SSE3 Technology: Yes
SSE4 Technology: No
EMMX - Extended MMX Technology:No
3DNow! Technology: No
Extended 3DNow! Technology: No
HTT - Hyper-Threading Technolo:No
Notice 5008: To change benchmarks, click Options.
Notice 5004: Synthetic benchmark. May not tally with 'real-
life' performance.
Notice 5006: Only compare the results with ones obtained
using the same version!
Warning 5009: Mobile processors yield lower indexes in
power management modes. Check power settings
if index is low.
tip.
<<< File Systems >>>
<< Hard Disk (C:) >>
Drive Index: 28 MB/s
Random Access Time: 10 ms
Results Interpretation: Lower index values are better.
Run ID: DAN-2444B21250E on 03 June 2006 at 19:17:27
Processor Affinity: No
Operating System Disk Cache Us:No
Use Overlapped I/O: Yes
IO Queue Depth: 4 request(s)
Test File Size: 503MB
File Fragments: 1
Block Size: 1MB
File Server Optimised: No
< Benchmark Breakdown >
Buffered Read: 30 MB/s
Sequential Read: 37 MB/s
Random Read: 27 MB/s
Buffered Write: 9 MB/s
Sequential Write: 9 MB/s
Random Write: 9 MB/s
Random Access Time: 10 ms (estimated)
< Drive >
Drive Type: Hard Disk
Total Size: 49GB
Free Space: 14GB, 29%
Cluster Size: 4kB
life' performance.
Notice 5209: Consider using the Removable Storage/Flash
Benchmark for Flash devices.
Tip 5202: Use cache on to measure Windows performance.
Warning 5205: Low write index. Check write verify is off.
tip.
<<< Physical Disks >>>
<< FUJITSU MHV2100BH (ATA) >>
<< Read Performance >>
Drive Index: 37 MB/s
Random Access Time: 19 ms
Run ID: DAN-2444B21250E on 03 June 2006 at 19:18:09
Block Size: 1MB
< Volume Information >
Capacity: 92GB
Speed at position 0%: 37MB/s (100%)
Speed at position 3%: 36MB/s (99%)
Speed at position 6%: 35MB/s (95%)
Speed at position 10%: 36MB/s (97%)
Speed at position 13%: 34MB/s (92%)
Speed at position 16%: 34MB/s (91%)
Speed at position 20%: 34MB/s (92%)
Speed at position 23%: 34MB/s (92%)
Speed at position 26%: 33MB/s (90%)
Speed at position 30%: 34MB/s (91%)
Speed at position 33%: 33MB/s (89%)
Speed at position 36%: 31MB/s (85%)
Speed at position 40%: 33MB/s (89%)
Speed at position 43%: 32MB/s (87%)
Speed at position 46%: 30MB/s (82%)
Speed at position 50%: 32MB/s (87%)
Speed at position 53%: 29MB/s (78%)
Speed at position 56%: 29MB/s (79%)
Speed at position 60%: 29MB/s (80%)
Speed at position 63%: 26MB/s (70%)
Speed at position 66%: 22MB/s (60%)
Speed at position 70%: 25MB/s (68%)
Speed at position 73%: 26MB/s (70%)
Speed at position 76%: 22MB/s (60%)
Speed at position 80%: 25MB/s (69%)
Speed at position 83%: 23MB/s (63%)
Speed at position 86%: 23MB/s (63%)
Speed at position 90%: 23MB/s (63%)
Speed at position 93%: 21MB/s (57%)
Speed at position 96%: 20MB/s (55%)
Speed at position 100%: 19MB/s (51%)
Random Access Time: 19 ms (estimated)
Full Stroke Access Time: 17 ms (estimated)
life' performance.
tip.
<< Write Performance >>
Error: Disk must be empty to be write benchmarked
for security.
this is the system summary, sorry for not having it posted as well. Hope you can help, hopefully we'll do a favour to other inspiron users as well.
I'm not sure if my hard drive is the problem...but I'm browsing for a firewire one supported by protools...
Thanks
Old 06-03-2006, 02:55 PM
An addition, I've made a simple test...run protools with the Lacie USB drive disconnected and monitoring the CPU on the windows task manager. The CPU goes at 100% as soon as I start Pro Tools and as soon as I close Pro tools the CPU goes down to normal levels.
I modified the bios settings as digidesign recommends, but the situation did not improve...
Old 06-05-2006, 12:33 AM
Problem Problem is offline
I have also problems with my Inspirion 6400 and M-Box 2.
I have the same errors, buffersize errors. It works terrible, at this time nearly useless.
The problem is that the chipset is so new, that it is not supported by Pro Tools.
I regret that I didīt checked the compatibility before I bought this laptop.
I hope that it will be supported soon by Pro Tools.
Many people have problems with Intel Dual Core PC-s, the same errors : buffersize errors.
Letīs hope that Digidesign can make an update, so this new Laptop can work with Pro Tools.
Regards
Johnny
Old 06-05-2006, 07:21 AM
I sort of managed to make it work "partially", as long as I use a few plugins pro tools seems to wark nearly ok with the occasional error. Good thing I'm not a Professional...but digidesign must solve this as computers and laptops will be increasingly using this type of CPU
Where did you find that the Dual core is not supported ? I checked the compato but it does not say that it's not compatible...
Old 06-05-2006, 07:45 AM
Hi
How did You get the 6400 to work better ?
Itīs the chipset in 6400, that its supported at this time.
The Chipset in 6400 is Intel i945PM.
Johnny
Old 06-05-2006, 07:47 AM
Default Re: Dell Inspiron 6400 and Mbox2, forgot NOT
Hi
Itīs the chipset in 6400, that itīs not supported at this time.
Johnny
Inspiron 6400 mcguffin00 Pro Tools M-Powered (Win) 0 06-21-2007 11:49 AM
Is an Inspiron 6400 compatible with an Mbox2 staffo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2006 10:37 PM
Dell Inspiron 6400 Equality 7-2521 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 10-09-2006 09:43 PM
Ordered Inspiron 6400 last night producertravis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-26-2006 08:30 PM
DAE ERROR 1115 on Dell Inspiron 6400 Cisco_kid81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-22-2006 07:33 PM
