Quick(Time) Question
Hi All,
I've migrated from the PT Mac LE forum to ask this, as you guys are supposed to be on top of your game: I'm working with QuickTime PAL DV movies imported into PT LE (without DV Toolkit) to work on a 35mm feature movie score. Do I still need to select a 'frame rate' and 'feet & frames' setting in a PT LE session, or are these options redundant and only valid with the DV toolkit? If so, what are the correct frame rate and feet & frame settings to sync to these QuickTimes? Any help appreciated... |
Re: Quick(Time) Question
Can you even select those things without the DV Toolkit 2? If so, frame rate would be 25. Feet+frames, I have no idea (not in film post).
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
Serato - Pitch N Time (Quick Question) | jordan23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-19-2004 07:41 AM |
Quick question: Time Limit? | spicyitaliano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 03-10-2004 08:33 PM |
Quick Time Question for Mr T. . . | Styles Bitchly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 03-26-2002 11:18 AM |
Quick Time question | Nostradumbass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-03-2002 12:23 AM |
2 part question - importing audio & Quick Time | threepac | Pro Tools TDM Systems (Mac) | 2 | 12-15-2001 10:35 AM |
