Old 11-01-2017, 12:48 PM
tlevine tlevine is offline
Default Do you use Artist Control or Artist Transport?
Hi there. I have three questions about Artist Control and Artist Transport...
Will these devices work with PT version 10.3.10 LE?
If I buy one of these devices used, must it include the original Avid installation CDs?... in order to work with PT?
Will the Artist Control let me use Memory Locations (so I can punch in halfway through the song, for example, instead of starting from the beginning)?
Thanks!
Old 11-01-2017, 05:51 PM
EddieJones's Avatar
Default Re: Do you use Artist Control or Artist Transport?
Thanks!
I'm pretty sure it does have EUCON. If you have it just open up peripherals settings and Ethernet and see if the option is there.
You will need the software EuControl...I can sort that out for you
Yes, You can use memory locations with the Control, you assign them to softkeys
Can I change Eucon Layouts with an Artist Mix or Artist Transport? amathie Artist Series 10 09-21-2017 07:29 PM
Need some help with Artist Control and Transport... Brian8377 Artist Series 0 04-16-2015 03:07 PM
HDX1, 8x8x8 I/O, Artist Mix, Artist Transport, AAX DSP plugs ArKay99 Buy & Sell 8 03-22-2015 01:12 PM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
Using Artist Control with Artist Transport? GrievousAngel Windows 2 03-14-2012 03:29 PM
