Am having troubles with my Fast Track Ultra on Windows 8 (x64). The device worked fine on my previous PC (Windows 7). On my new PC the device registers perfectly, however if I play something such as a song after some time between 5 and 30 seconds the music sounds all crackled and sometimes mutes. A lot of artifacts / static / crackles can be heared and mixes in with the music. I have the latest drivers installed and have tried every single USB port on my PC. I have even installed two separate USB headers just to be sure the USB port would not be the problem. Also I have been fiddling with the buffer size to no avail.
Any ideas on how to fix this? It renders my Fast Track Ultra unusable. |
Hi and welcome to the community
![]() Here are a few threads you can look at where some members have had this same issues and solved them with various solutions http://duc.avid.com/showthread.php?t...st+track+ultra http://duc.avid.com/showthread.php?t...st+track+ultra http://duc.avid.com/search.php?searchid=7166398 Hope you get that fixed asap Best Regards Christopher
Another user has posted a possible workaround for this problem: http://duc.avid.com/showpost.php?p=2...&postcount=103
Might be worth trying. Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 7 5700X / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Thanks guys, I reverted to driver 6.0.2. and that fixed the problem. Although it is a Windows 7 drivers it works perfectly.
Thanks to all for previous post regarding this problem!! For me, my Fast Track Ultra was working flawlessly with both streaming audio from Windows, as well as with playing and recording instruments through it.
When I upgraded to Windows 8.1, I installed the 6.1.9 release from the Avid site. Then I had audio glitching, plus complete sound muting. The only work around I had found so was switching from the Fast Track Ultra playback device in the Windows volume mixer to either my internal sound card and back again. Even then, the problem muting would started again randomly, but most often after approx. 5min. Really annoying!! Thanks to mcrooney's suggestion had I tried "backgrading" to 6.0.2. It is much better. I was brave to then try 6.0.8, and actually find on my computer it audio is even more glitch free. Thanks so much!! |
Fast Track Ultra - Sound glitch at 96Khz in Windows 8 | Readysound | FireWire & USB Audio Interfaces (Win) | 9 | 12-28-2013 01:07 PM |
Fast Track Ultra - Big thanks and a wish... | C.O.D. | FireWire & USB Audio Interfaces (Win) | 3 | 08-29-2013 05:35 PM |
New PT10 User. MBox3, MAudio Fast Track Ultra, MAudio Fast Track 8R? | epu | Pro Tools 10 | 3 | 06-13-2012 03:55 PM |
track confusion in fast track ultra interface | deck | Pro Tools M-Powered (Win) | 0 | 02-24-2010 10:17 AM |
Fast Track Ultra with Pro Tools 7 M- Powered for Windows | NERO1 | Pro Tools M-Powered (Win) | 0 | 02-25-2008 09:48 AM |
