Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 11-27-2013, 04:30 PM
gregpetre gregpetre is offline
Default Low headphone volume on mbox 3 pro
Hey guys,
I've been searching for the cure but can't find it. I'm running PT 11.0.3 just fine with current drivers in my mbox 3 pro.
On headphone A , even when in the control panel I have the master volume all the way up, hardware inputs 1/2 all the way up. I'm running a dynamic mic in input 1 on the box, the gain is where I want it on the meter level......but I have to turn the headphone volume all the up to 4 o'clock to get to an almost acceptable headphone volume, but it could be louder. It makes the singer naturally get too close to the mic, and have to sing louder than comfortable.
This can't be normal and I assume there must be some other setting to adjust so I can crank the headphone volume as loud as needed for the vocalist.
Please help!!! Thanks in advance, Greg
Old 11-27-2013, 04:51 PM
Default Re: Low headphone volume on mbox 3 pro
What exact model headphones? What is the impedance? High impedance phones(like 600 ohm AKG 240's) will be much softer than low impedance phones(like 32 ohms). Start with that spec before you blame the Mbox. Next, I would look at the settings in the monitoring software(which I don't use, so I can't offer any better advice)
Old 11-27-2013, 05:14 PM
Thanks Dave. I am using Beyer dynamic DT 770 pro -- 80ohms impedance 5-35,000 hz frequency response. I can crank them all the way headphone volume to the right, but could use a little more volume.
I just checked that same volume setting with my cheaper audio technicas ATH-M30 at 65 ohms. The volume sounds roughly the same.
Old 11-27-2013, 06:01 PM
After going through my control panel settings, I'm starting to think I should just get an external headphone amp and run my signal out the headphone jack. It just doesn't make sense that there wouldn't be enough extra volume on the stock mbox. Hmmmmmmm.........
When listening back on my monitors, there is MORE than enough volume from the master volume dial.
Headphone b volume low....Mbox 3 Pro Mahkyb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-29-2012 07:31 PM
Mbox 3 Pro Standalone Headphone Volume jrk87 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-01-2012 06:03 PM
Eleven Rack headphone port versus MBOX and other interface headphone ports World Spirit Eleven Rack 3 02-12-2012 11:34 PM
Low headphone volume MickFowler Pro Tools M-Powered (Win) 1 10-20-2010 10:48 AM
Headphone/Monitor Volume on Mbox 2 Mini idylldon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-01-2007 09:18 PM
