Old 01-13-2013, 07:20 PM
goatfish goatfish is offline
Default Blackmagic Extreme & playback engine issue
version pro tools - 10.3.3
blackmagic extreme 3d - 9.6.9
mac - 10.8.2
2 x 2.66 GHz 6-core intel xeon
16 GB 1333 MHxz DDR3
This is a brand new machine, new Pro Tools install and new audio/graphics card. Audio input and output tested in media composer and working fine.
This issue I'm having in Pro Tools is the playback engine provides two entries for the blackmagic card. The first one maps input channels but not output channels so that on the track and mixer routing it says "mapped output inactive no path available". If I click on the other blackmagic entry in the playback engine I get the opposite - "shows all paths input n/a, no input mapping but output mapping. I am able to playback and hear audio with this second entry (but not the first) but the main issue is I cannot record within either setting due to PT's requiring active activation of both input and outputs but I can't figure out a way to set them both up. The error message I get is this one;
"track could not be record-enabled because it doesn't have both an active input and output assigned"
I don't know why PT's is seeing these two instances of the blackmagic card rather than just one. I have loaded and unloaded both PT's and the blackmagic drivers but to no avail. When the blackmagic drivers are unistalled they are not present in the playback engine as expected.
I have no idea what to do about it.
Simon
Old 01-14-2013, 01:16 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Blackmagic Extreme & playback engine issue
They won't be if you've uninstalled them!
This looks like the blackmagic drivers hasn't been written very well if its giving you 2 audio engine! one for inputs and one for outputs
The option might be to use an Aggregate audio device using the 2 blackmagic drivers.
lookup aggregate audio device on Google you'll find lots of details for creating one.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-14-2013, 03:53 PM
Well I did reinstall them! but thanks for the tip, will look into it right away.
Old 01-14-2013, 04:01 PM
Hugh-H Hugh-H is offline
Hello,
It's somewhat common to have two playback engines, one for input and one for output. The built in I/O in the MacOS does just that - the input is one and the output is another.
As mentioned, create an Aggregate Device. Be sure they're set to the same sample rate and select the input as the master clock.
Hugh
Old 01-14-2013, 04:38 PM
So creating the aggregate has at least allowed me to arm the track for recording.
Still can't get audio in nor hear playback now. Going to hit the blackmagic forums.
Old 01-14-2013, 07:04 PM
I got an answer from local Avid support - just not going to work.
It won’t work. The Blackmagic card can be used as a video interface but they need a proper, qualified audio interface.
http://duc.avid.com/showthread.php?t=291932
Seems odd that I can record audio in Media Composer (thankfully) but not Pro Tools. Thanks to those who offered some help.
Old 01-14-2013, 07:06 PM
Got an answer from local Avid support - it just doesn't work.
"It won’t work. The Blackmagic card can be used as a video interface but they need a proper, qualified audio interface."
Old 01-14-2013, 07:19 PM
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
Nvermind - Found a better thread. SD playback in a Blackmagic HD Extreme 3D minister Post - Surround - Video 0 03-28-2011 09:32 PM
blackmagic extreme and pro tools 8.0.1cs djoeyd77 Pro Tools TDM Systems (Mac) 0 06-22-2010 09:33 AM
Can i use the Blackmagic HD Extreme on my PC vudoo Pro Tools TDM Systems (Win) 5 01-05-2010 07:00 PM
Blackmagic Decklink Extreme - Anyone tried it? StefB Post - Surround - Video 1 06-17-2005 10:27 PM
