I've noticed that my headphone b is a bit low. Do
I go into the Mbox control panel and raise the channel fader? In my case, It would be channel 5? Also, can headphone a & b be on different channels? |
So, nobody has experience with this??????
From the Mbox Pro User Guide:
I saw that in the user guide but I was still confused.
When I originally looked in the control panel Heaphone A was set to channel 5 and B was set to 6. I was only getting audio out of A. I read a thread where someone just switched B to channel 5 and then I started getting audio. Great! Problem is.....now that both outputs are using channel 5 the volume seems low when using the headphone B output. So, can I somehow raise the volume level of B in the control panel? If so, how? Also, why can't headphone outputs A & B be on different channels? |
Anyone else?
Wednesday Hump Bump......
Friday bump.....so, no takers huh?
You should have it in stereo - 1/2, 3/4, 5/6, etc.
I always have both in the master out, in my case it's always 1/2. There were some issues with the old drivers with phones but 1.0.16 took care of that, and now they have 1.1.2 for ML. Sent from my iPhone using Tapatalk
MacBook Pro Retina M4Max, 128GB RAM, OSX Sequoia 15.5, PT Carbon, PT Ultimate version 2024.10.2, Glyph External Drives. Outboard gear - RND Shelford Channel, API TCS II, SSL Bus +. |
![]() Quote:
Maybe that will give you more of an idea of my problem.... |
PM if u wish!
Low headphone volume on mbox 3 pro | gregpetre | FireWire & USB Audio Interfaces (Mac) | 3 | 11-27-2013 06:01 PM |
Mbox 3 Pro Standalone Headphone Volume | jrk87 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-01-2012 06:03 PM |
Eleven Rack headphone port versus MBOX and other interface headphone ports | World Spirit | Eleven Rack | 3 | 02-12-2012 11:34 PM |
Low headphone volume | MickFowler | Pro Tools M-Powered (Win) | 1 | 10-20-2010 10:48 AM |
Headphone/Monitor Volume on Mbox 2 Mini | idylldon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-01-2007 09:18 PM |
