Old 03-18-2012, 08:09 AM
nedd nedd is online now
Default Command 8 & V-control surr panners
I've just discovered that this two can work nicely together. Normally, C8 doesn't allow additional HUI controller and actually you don't use this one of V-Control (so no transport and other controls with V-Con), but if you use only two V-Pan controllers, (V-Pan 1 and V-Pan 2) it works great together.
Also, if you need not surround panners, you could temporarily select V-Window and for example have there Automation window or any other window in Pro Tools.
If this was covered somewhere else I do apologize for repeat.
Old 03-19-2012, 08:39 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default
I have a ProControl and I can not have more than one midi device with ProControl - so I can't get the surround panniers to work, which is a bummer.Anyone know of a way around this?
Cheers
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
HTML code is On
command 8 /control 24 or other control surface for HD 68topls Pro Tools TDM Systems (Mac) 0 12-26-2009 12:25 PM
Control 24 / command 8 or other control surfaces with HD 68topls ICON & C|24 0 12-21-2009 05:47 PM
Tactile control of PTLE without Command|8 Control|24? Blackshapes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-05-2009 09:39 PM
Bounce Surr Audio 5.1 to a Quicktime Movie in PT gives Post - Surround - Video 7 03-02-2007 02:57 PM
How come my panners only control volume??? Bryon Needs help 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-23-2003 02:08 PM
