Old 08-13-2011, 05:51 PM
LewKellogg LewKellogg is offline
Default PT9, Mac Pro, 10% CPU, 2GB mem used, still says Running Out of CPU and/or Memory
The title says it all.
I am running a Mac Pro Quad with 8GB of memory, Snow Leopard in 64 bit mode, latest PT 9.03 (yes I know it is 32 bit only), correct drivers, etc. And yet, I run out of CPU, or HW buffers, or something.
Activity Monitor says I only utilize 10% max CPU and that I only use 1 to 2 GB of memory. And yet, PT stops and tells me I either have a CPU issue, memory issue, or something. Sounds like something is off a bit.
Has anyone experienced similar?
Lew
Old 08-15-2011, 04:10 PM
Default Re: PT9, Mac Pro, 10% CPU, 2GB mem used, still says Running Out of CPU and/or Memory
Ok, maybe the title doesn't say it all. How about a -9128 error code?
Old 08-15-2011, 07:07 PM
Did you set your playback settings properly? As a general rule, it should be set to use less processor cores than you actually have. If you have an 8 core processor, try setting to to 7 processor cores or lower. I know it sounds counter-intuitive but, basically you are leaving some processor cores free to handle non-realtime duties that is needed by Protools and the OS.
Obsidian Dragon
MacOS 13.6.7 running Protools 2024.6
Mac Studio M1Max - 64GB
MacOS 14.5 running Protools 2024.6
Old 08-27-2011, 04:34 PM
Thanks. Strangely, as you suggested, it worked.
PT running out of memory Blackers Pro Tools M-Powered (Win) 10 06-30-2011 12:59 PM
PT HD9 (running native with motu) running out of memory syMPh Pro Tools TDM Systems (Mac) 1 11-21-2010 07:34 PM
DAE Running out of memory... mandinga79 Tips & Tricks 1 12-18-2009 08:07 AM
PT Running out of memory JohnR424 Pro Tools TDM Systems (Win) 20 06-11-2009 10:15 PM
Running out of memory? Scott Cairns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-31-2007 08:20 AM
