Old 05-02-2010, 12:36 PM
ergalthema ergalthema is offline
Default Move selection only - not region
This one is hard to search for.
What is the setting that allows me to make a selection inside a region, then just grab and move that selection only?
Right now, when I make a selection, then grab it, it selects the entire region.
Mid-2014 15" MBP Retina 2.8GHz Intel Core i7, 16GB DDR3, OSX 10.10.5, PT11.3.1 003 Rack Factory.
Old 05-02-2010, 03:05 PM
Default Re: Move selection only - not region
Nevermind. I spent way to long finding it in the manual. I needed to change the grabber to "Separation".
Old 05-02-2010, 03:49 PM
tlennon tlennon is offline
You got it. Also, take a look at the shortcut PDF. This will help your workflow 10 fold. Best wishes!
Terrence Lennon
Ivory Key Productions
Old 05-02-2010, 04:54 PM
Thedspeth Thedspeth is offline
⌘-E after you make your selection will cut a new region.
(I use this most when i'm muting... so it's ⌘-E then ⌘-M)
Pro Tools 9
Symphony I/O
Mac Pro 8 core
Gear: UA 6176, UA 2-1176, Daking IV, Presonus ADL-600, 2 GAP PRE73
Other Software: Ableton 8, Reason 4, Sibelius 6
Plugs: Mercury Bundle, Full UA
Old 05-02-2010, 05:05 PM
Thanks. I use split region all the time, but it's an extra step when I just want to move a selection. I'm still trying to figure out why anyone would not want separation on...
Old 05-02-2010, 06:14 PM
Basically because it is a secondary tool and there is no shortcut to change the tool back to the default setting which is used most of the time. So the shortcut of Ctl-E was born. Then all you have to do is drag the selection with the mouse.
Terrence Lennon
Old 05-02-2010, 06:26 PM
By default setting do you mean grabber tool without "separation"?
I'm saying that I don't see the benefit of having the grabber tool without separation.
Very often I want to copy a selection of a region (option + click) without splitting the region. Using E creates a bunch of messy-looking splits imo.
Maybe it's just workflow preference.
Old 05-02-2010, 07:08 PM
Yes that what I'm talking about. However, if that is your workflow then you're good to go with setting to separation and forget about. It's all about user preference which is nice that they give you a choice.
Terrence Lennon
Map jog wheel to move edit selection up and down? studioj11 Artist Series 5 11-15-2013 12:31 PM
"Move Selection" key command LK7 Tips & Tricks 2 03-19-2007 08:10 AM
Edit Selection Follows Region List Selection->NOT! alteregg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-14-2006 03:40 PM
Reverse selection end move command (R.S.E.M.C.)? Mick F. Cantarella Tips & Tricks 3 05-09-2003 10:41 AM
Reverse selection end move command (R.S.E.M.C.)? Mick F. Cantarella Pro Tools TDM Systems (Mac) 2 05-04-2003 11:15 AM
