Old 12-17-2009, 03:16 PM
mandinga79 mandinga79 is offline
Default DAE Running out of memory...
Bounced a session down to wave file, and imported it into new session for mastering.... when I went to add the L2 plugin to my masterfader - the first, and only plugin on there, I received the message - "DAE running out of memory." It then made the plugin inactive. I've never had this issue before... I tried allocating more resources on my mac - in the setup window, buffer sizes, etc. not working.
I've used this methodology before in mastering projects - this is the first time this has happened.
Please help!
thanks.
Old 12-18-2009, 08:07 AM
daeron80 daeron80 is offline
Default Re: DAE Running out of memory...
If rebooting doesn't help, you should delete this thread and post one in the appropriate forum - Mac or Windows LE, as the case might be - along with full system details as outlined in the Help Us Help You sticky at the top of that forum.
David J. Finnamore
PT 2024.10.1 Ultimate | Clarett+ 8Pre | macOS 14.6.1 on a MacBook Pro M1 Max
PT 2024.10.1 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
PT9, Mac Pro, 10% CPU, 2GB mem used, still says Running Out of CPU and/or Memory LewKellogg macOS 3 08-27-2011 04:34 PM
PT running out of memory Blackers Pro Tools M-Powered (Win) 10 06-30-2011 12:59 PM
PT HD9 (running native with motu) running out of memory syMPh Pro Tools TDM Systems (Mac) 1 11-21-2010 07:34 PM
PT Running out of memory JohnR424 Pro Tools TDM Systems (Win) 20 06-11-2009 10:15 PM
Running out of memory? Scott Cairns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-31-2007 08:20 AM
