Old 11-02-2009, 01:11 PM
lululu lululu is offline
Default record enabling a group of tracks
Hi
On PT HD I can set the group definitions to say follow master and in the master group setup I can select record as a "follow item"
I'm missing this feature in PT LE 8, even with DVtoolkit...
Am I missing something?
Is there a workaround ? (apart from selecting the desired tracks and shift alt click record)?
Cheers
M
Old 11-05-2009, 07:48 AM
Default Re: record enabling a group of tracks
anyone? Please
Old 11-05-2009, 08:37 AM
flommer flommer is offline
Seems to be a limitation of LE...
Only similar thing I could find is, If you first high-light the tracks you want to record enable, then holding shift-option while clicking the record enable button enables all the highlighted ones, plus the one you are clicking (in case you click on one that is not highlighted)
I guess if you are repeatedly enabling/disabling the same group then you can prepare by selecting the tracks first.. If you are going back and forth between different groups then it won't save much time..
Not the same, sorry..
It is strange the things that they cripple in LE, sometimes.. Almost as if just to be irritating..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 11-05-2009, 08:40 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
If ur wanna to do groups as such, u just make sure that "Link track & edit selection" is checked, that way when u select one track in the group they will all be selected & then just hold Shift-option as Flommer said & ur good... Pretty simple...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Problem when record enabling stereo tracks! Herokazz Windows 5 10-19-2012 05:34 AM
Record enabling multiple tracks joshfrog94 Pro Tools 9 2 11-14-2010 12:33 PM
LOUD Click when record enabling tracks in 7.3 cfb25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-14-2006 06:46 AM
Group Not Record Enabling Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-08-2004 03:40 PM
Record-enabling several tracks at once j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 03-05-2002 02:32 AM
