Old 01-02-2009, 07:48 PM
Trainwrecker Trainwrecker is offline
Default Record pass is visually impaired
M-Box Pro
XP-Pro Sp3
4 gig ram
Q6600
Asus P5K Prp
Version 7.4
When I record a track the wave is "Blocked" (solid colored) as the recording is progressing down the swim lane. I have spent some time trying to undo this visual but no luck.
Any suggestions? Hope it is a face palm fix.
Old 01-02-2009, 08:13 PM
tha]-[acksaw tha]-[acksaw is offline
Default Re: Record pass is visually impaired
have you switched the view menu on the track from "block" to "waveform"
forgive me if im not understanding you correctly
there is also a waveform issue with LE 7.4 in which the waveform in not accuratly represented. sometimes there will be gaps in the waveform that are not really there, or the waveform will be misrepresented in other ways, like being early or late, or in no way true what the actual waveform should look like. they fixed it in the cs 8 update.
hope this helps!
Nick
www.TheSoundCoop.com
www.youtube.com/TheSoundCoop
PCAudioLabs 2.5GHz Quad-Core Q8300 FSB:1333/1066MHz, NB:IntelG33, SB:Intel ICH9DH/WinXP Pro SP3 / SATA HD's = 160GB(7200/8), 320GB (7200/16) x 2,500GB (7200/32) / 4GB DDR2-800 / FW = TI ChipSet / Gear: Apogee Rosetta800, ADL600, Avalon2022 // M-Audio = Profire Lightbridge, Octane 8's, BX5's BX8's & SBX // ProTools MP 8.0.5 w/ MPTK 2 - Velvet Waves Sonnox IK NI FXpansion Massy -- DVerb2.0 Test = 230 verbs
Old 01-02-2009, 08:27 PM
It is not the "block" to "waveform" switch.
As I record a track, there is no waveform being created as the recording progresses. It is just a solid color (the whole lane behind the cursor is just a solid color as I record the track.
When I am finished (take 42) the wave form appears and the solid color is gone. The sold colors only appear when I am recording.
Old 01-02-2009, 08:43 PM
Greg M Greg M is offline
Trainwrecker,
I'm pretty sure it's a bug. I have seen this "feature" come and go from various versions, but it was definitely impaired in 7.4cs8 for me (using an 002r and AMD Opteron 265 Quad). Not sure what causes it but I never got too hung up on it either. I just watched the meters while recording and, as you noted, when you finished recording the track the wave form appeared. (You never got a wave form view recording to tape and things worked out.)
FWIW, things are normal again in PTLE 8 - the wave form draws while recording.
I know this is not much help, but sometimes it's good to know you're not alone.
Greg
Old 01-02-2009, 08:54 PM
If it was a perfect world I would be watching the producer!
I am going to bump to the 7.4CS8 and see what gives.
For how long can I record on a single pass? M&Mguy Pro Tools 10 8 12-09-2013 09:39 AM
DCI Spec for the Visually Impaired Audio Levels ZigZagZig Post - Surround - Video 0 07-11-2013 01:23 PM
Record disabling after each pass Oli P Pro Tools TDM Systems (Mac) 2 04-04-2008 08:31 AM
OT: audiosoftware for the blind/visually impaired Arno Peeters General Discussion 1 07-28-2006 02:05 AM
Pro Tools for Visually Impaired BigG79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-21-2004 12:00 PM
