Old 12-03-2007, 07:15 AM
houseofoaktree houseofoaktree is offline
Default MBOX PRO 2 STEREO INPUTS!!???
Hi
I have recently purchased a digidesign MBOX 2 PRO. I use it with my INTEL IMAC. I have recently tried recording a pair of BINAURAL MICROPHONES through the MBOX and realised that all the MBOX inputs (apart from the AUX IN) are MONO! Does anyone have any ideas as to how I can record STEREO! I cant believe a product that cost £450 doesnt have STEREO inputs! My BINAURAL mics have a stereo 3.5mm output so im hoping to get a splitter to plug into my MBOX 2 PRO's DI input 1 & 2. But does anyone have any IDEA how I record microphone in stereo through the XLR inputs at the back?! What if I want to use an AKG C414 using figure of eight!? Not inpressed with this product or company at all! Any ideas is much appreciated!
Cheers
Tim
Old 12-03-2007, 08:01 AM
Phil Ogden Phil Ogden is offline
Default Re: MBOX PRO 2 STEREO INPUTS!!???
A 'Y' or splitter cable should work. Then, as you quite rightly have identified, patch it into 2 inputs. Assign these to a stereo or 2 mono tracks and away you go.
Old 12-03-2007, 08:28 AM
DigiTechSupt's Avatar
Cheers
Tim
Yes - you would use 2 mono microphones, each going into a separate input (the 414 is mono, even in figure 8 pattern...). If you're using a true stereo microphone, it will have 2 outputs, one for each of the left and right channels.
Avid Audio Tech Support
Support FAQ
Old 12-03-2007, 11:18 AM
Mr. Anderson Mr. Anderson is offline
Are you serious?
Name me one product or company that has a professional audio interface with a 3.5 mm stereo input.
I could have chosen any interface made by any company, but I chose the same interface that you did. I suggest you do yourself a bit of research before coming in here and slamming Digidesign for a really silly reason.
using stereo inputs francois ICON & C|24 1 07-04-2012 09:52 PM
Can this be? Only 16 stereo inputs in PT9? MacPC Pro Tools 9 98 03-22-2011 08:53 AM
D-Command Stereo inputs Reckless Erik ICON & C|24 3 05-24-2007 01:33 PM
DIGI 002 inputs - mono or stereo? JLSIII 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 05-08-2005 03:29 AM
can' t cofigure stereo inputs desil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-26-2001 03:56 AM
