Old 03-26-2007, 01:41 PM
meghi meghi is offline
Default trouble with digi 002 in standalone mode,please help
Hello!
My name is Meghi,I am from romania.
I have a problem with my DIGI 002.
I use it in standalone mode,and last week after 4-5 hours of using,it turn off and turn on without touchin' any button.I set it again in standalone ,it works 5 min.,and turn off again.
It start again,but is remaining in "validating".I try 2-3 times to start it but ...nothing.only the lights and 3 yellow points appear.
After 3 or 4 days I start it again and surprise...it was working.Unfortunately,only for 3 hours.
Tell me please,if you know what's the problem and what to do.
Thank you very much, looking forward to hearing from you.Meghi.
Old 03-27-2007, 06:45 AM
Default Re: trouble with digi 002 in standalone mode,please help
Do a search for "POWER HARNESS" as that is what the problem sounds like. Its a very common problem with the 002 and the fix is usually as simple as opening the bottom panel and unplug-replug all the plastic connectors on the harness. Do each connector 5-6 times to clean oxidation from the pins and sockets. The entire job should only take you 15-20 minutes.
Digi 002 Standalone Mode and MIDI agprimatic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-09-2010 06:50 PM
Digi 002 Standalone Mode DJ Mozaic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-29-2010 06:19 AM
Digi 002 in standalone mode with ADA8000 mal777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-20-2006 04:48 AM
Digi 002 in standalone mode with ADA8000 mal777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-19-2006 01:51 AM
Digi 001 w/NI Kontakt (Standalone Mode Problem) Earthling Tips & Tricks 0 02-10-2004 09:34 PM
