Old 01-07-2007, 09:14 PM
ccBob ccBob is offline
Default Using PT with multiple users
Is it possible to use PT with more than one user on the same Mac?
Basically, I have PT 7.1 installed on my main account (PowerBook G4). Since I have a lot of apps running in my main account, I was going to setup a new account only for use as a DAW - this way I could disable anything that would prevent PT from running optimally. But, when I try to run PT from the new account, it simply crashes.
Any ideas on how this could be performed, or do I need to reinstall PT on the DAW account?
Thanks for any info.
Bob
Old 01-07-2007, 10:12 PM
Barry Johns Barry Johns is offline
Default Re: Using PT with multiple users
Create differenet user acconts on your mac. Each user will have thier own preferences. Try it, it should work.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 01-08-2007, 03:01 AM
arnonAtron arnonAtron is offline
i think i know what your problem is
you have to give that second account admin privileges
pro tools requires that the user has admin privileges to run
it's just one of those things ..
but if you don't mind that
your second account should run fine
MACPRO-2.66ghz-5GB RAM/MAC mini-1.5Ghz-1 GB RAM/ibook-G41.42ghz-1.5 GB RAM/DIGI 002/Mbox 2/Mbox2mini/ProToolsLE 7.3.1
Old 01-08-2007, 04:26 AM
Thanks Barry.
I tried this and PT still crashes on startup.
Old 01-08-2007, 04:33 AM
Thanks arnonAtron.
The new account has admin privileges, but PT still crashes. I even experimented with changing ownership of the entire DigiDesign folder to the new account, but still the same result.
Old 01-08-2007, 09:06 AM
DigiTechSupt's Avatar
Try removing all your plug-ins from your plug-ins folder - if Pro Tools doesn't crash, you'll know it's plug-in related. I believe Native Instruments and a few other plug-ins may need some tweaking to work under a second account.
Avid Audio Tech Support
Support FAQ
Old 01-08-2007, 06:32 PM
Thanks for the suggestions. I tried removing the plugins, but it still fails.
Rather than waste too much time on it, I simply removed PT and reinstalled it in the DAW account - since this is where the bulk of the work will be done.
Thanks again.
Bob
multiple users and LE invaderhalomaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-06-2005 02:17 PM
Multiple Users in OS X arconaut Pro Tools TDM Systems (Mac) 7 02-24-2005 06:36 PM
Multiple users trickyjw Pro Tools TDM Systems (Win) 1 03-23-2004 10:05 AM
Multiple Users for PT6 Goodman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 08-07-2003 08:10 AM
Multiple users Justin Pro Tools TDM Systems (Win) 1 04-20-2000 11:07 AM
