Old 06-24-2006, 10:49 AM
jkatcher jkatcher is offline
Default Automation on SAVED plug in settings
Hi all -
Does anyone know if there is a way to use automation to jump between settings that have been saved on a plug in, as opposed to manipulating each parameter separately?
thanks so much!
Old 06-24-2006, 08:51 PM
Matt Chan Matt Chan is offline
Default Re: Automation on SAVED plug in settings
i'm not totally clear on what you're asking but you can use glide automation to transition between two entirely different plug-in states (such as say, two different EQ profiles). it is a bit hard to explain how to use it, so it's probably best to look it up in the manual. you'll need to be at least at 6.9 TDM
Old 06-26-2006, 01:42 AM
mr.armadillo mr.armadillo is offline
Look up "snapshot automation" in the reference manual. This will do the trick.
HTML code is On
Plug in settings saved as "clippings" like DP filobus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-20-2010 01:43 AM
Plug in saved settings? Jono_G 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-25-2010 06:13 PM
Automation of Plug-in Settings dsetaro Tips & Tricks 2 12-24-2007 07:35 AM
Can you retreive saved plug in settings via automation? Rob S Pro Tools TDM Systems (Mac) 3 11-23-2007 06:36 AM
are plug-in settings....... saved?? gitarzan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-12-2003 11:27 AM
