Old 01-27-2006, 10:55 AM
Primo Don Primo Don is offline
Default How long can I record in a single pass?
You guys are great, by the way. I'm learning this stuff and you folks are invaluable. Thank you.
Anyway, I want to record live, just me and the acoustic (or me/acoustic and a 2nd singer/acoustic) and want to just run out of my board to the MBox, two tracks, or maybe even one (and hope the board mix is good enough.) My Glyph drive is the 80 GB one. How long can I record one and two tracks?
Recommendation on sample rate to maximize record time? This is mostly for posterity.
Thanks again! Adam
iBook G4, 1.42 GHz, 1.5 MB Ram, OS X.4.4
LE 7.0 MBox 1, Glyph HD
Waves RenMaxx
Old 01-27-2006, 11:02 AM
Default Re: How long can I record in a single pass?
http://www.digidesign.com/compato/osx/stg/le.cfm
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-27-2006, 11:27 AM
I looked over the compatibility document but I think I'm missing what I'm supposed to be looking for. I have the disk space--2 tracks, 60 minutes, 24-bit @ 96 kHz is 1.9 GB. Can a single region be 60 minutes or longer? I'll of course divide them up when I do the "mix"...
Waves RenMaxx
Old 01-27-2006, 11:38 AM
Slim Shady Slim Shady is offline
Yes. In PT's preferences, you can change the disk allocation for record time, but by default it's set to 'open ended' which means it'll just keep going until you hit the size limit.
Old 01-27-2006, 12:30 PM
You're missing the maximum file size supported by Pro Tools which is on that document -- based on the sample rate it'll define the maximum record length.
Look and you shall find.
Pro Tools has a single audio file size limit of 2048 MB. This equates to about 4.5 hours at 24-bit, 44.1 kHz.
Rail
Platinum Samples
Old 01-27-2006, 01:12 PM
Ah yes. So I found this: Pro Tools has a single audio file size limit of 2048 MB. This equates to about 4.5 hours at 24-bit, 44.1 kHz.
2048 MB, or 2 GB, right? 1.9 MB is 60 minutes of a stereo recording in one pass at 24-bit/96 kHz according to another reference book I have. And all this is dependant on whether my Glyph can hadle it that long, too, of course. And I *could* reduce the bit-depth/sample-rate to be on the safe side...
Waves RenMaxx
Old 01-27-2006, 05:21 PM
... or make a selection in my post above my name and you'll find the same info.
Rail
Platinum Samples
For how long can I record on a single pass? M&Mguy Pro Tools 10 8 12-09-2013 09:39 AM
Record pass is visually impaired Trainwrecker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-02-2009 08:54 PM
Record disabling after each pass Oli P Pro Tools TDM Systems (Mac) 2 04-04-2008 08:31 AM
One Session Is Shutting down After each record pass..Why? As Is 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-13-2008 05:00 PM
How long until single processor rtas probs fixed? J.D. Andrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-07-2006 04:53 PM
