Old 07-16-2004, 05:26 AM
TimeWorm TimeWorm is offline
Default mBox : Digital Noise
Got my mBox connected to a AMD XP2800+, 2.083MHz, 512 MB RAM. My harddrive is a Seagate S-ATA 160GB 7200RPM... When the harddrive is working, there appears a noise witch is not that loud, but annoying.
Should I get an additional harddrive? Does S-ATA drives make more noise than IDE?
Thanks for reading and replying!
Old 07-16-2004, 07:31 AM
Bazzle Bazzle is offline
Default Re: mBox : Digital Noise
Do you mean noise as in the sound of the harddrive spinning?Or digital noise in the monitors?Do you have SP1 installed?
Bazzle
Old 07-16-2004, 07:37 AM
lemix's Avatar
lemix lemix is offline
Welcome to the Asylum,
Do you hear "static " ?
Try a different USB port.
cheers,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 07-16-2004, 04:01 PM
Everytime the harddrive is working, I can hear it in my headphones, clicking/spinning syncronically with the harddrive... SP1 is installed.. And I tried all my USB ports......
Old 07-16-2004, 04:46 PM
lemix's Avatar
have you tried a different power source for your PC/?
can you borrow/rent/buy a powered USB Hub and see if it's better ?
good luck,
cheers,
Andrew
Old 07-16-2004, 10:39 PM
Just curious, is the Mbox sitting on top of the computer?
Old 07-17-2004, 05:26 AM
cdp2004 cdp2004 is offline
I'm having the same problem. And I still haven't found the answer. When I run my mbox straight to my powered montiors I don't hear a thing. But when I run it to the mixer I can hear it
Old 07-17-2004, 02:42 PM
After weeks of trying I have found the answer to it in my system. It wasn't the MBOX, PC or Mixer. I found that my EMU keyboard I had plugin into my mixer was the cause of a ground loop. So I had to put $1.50 ground adapter on it and it worked like a charm. If I had known that I would have done it sooner. Hope that helps.
Old 07-18-2004, 06:05 PM
Hmm, more on the clicking noise : When I'm scrolling the mousescroll (the middle scrollbutton on the mouse), the sound is especially loud....
Old 07-18-2004, 06:21 PM
lemix's Avatar
did you try a standard PS2 connection for it ?
cheers,
Andrew
Crackling and Digital Noise with PC, PT 9 and Mbox 2 ChrisTWR Windows 2 06-07-2011 05:26 PM
Digital noise using Mbox 2 joey141 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-06-2009 12:54 PM
Mbox and Digital noise northridgedave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-11-2007 10:50 AM
mbox cumulative digital noise jimkonczyk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-26-2004 02:04 PM
Digital noise emitted from Mbox oedipus_complex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-15-2004 03:24 AM
