Old 01-17-2011, 01:52 PM
Gabriel_S Gabriel_S is offline
Default Can't change sample rate
Ok, so I've been experimenting with PT MBox 3rd generation with a sample rate of 48k. I'm ready to start putting projects into pto tools. Problem is, every time I start a new session it defualts to 48K. I'm unable to change it within the hardware options in Pro Tools, I tried shutting down Pro Tools and changing my settings to 44.1 in the MBox setp. I was able to change it there, but as soon as I start a new session, it again defualts back to 48k. I'm sure I'm missing something plain as day but would appreciate a push in the right direction.
Thanks so much
Gabriel
MBox 3 | PT LE 8.0.4 | Toolkit 2 | AMD Phenom™ II X4 3.2 Ghz with Arctic Ice | Seagate 500 gig (OS) and 1.5 Tb (Audio) HDs, 32 mb cache each | Gigabyte MOBO | Windows 7 64 Pro | 4 gigs Kingston DDR2 1200 Hyperextension Ram | 750 watt power supply | Antec Sonota 111 case | Dual 24" monitors |ATI Radeon Graphics card | Korg Triton Extreme | Korg M3 | Guitars
Old 01-17-2011, 02:06 PM
Default Re: Can't change sample rate
NM, figured it out :)
Gabriel
Old 11-11-2011, 08:02 AM
crandallwarren crandallwarren is offline
I'm having this same problem with my Mbox 3. What did you figure out?
Thanks!
C. Randall
Old 04-20-2012, 11:43 AM
Winnorf Winnorf is offline
I have the same problem.
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
Can't Change Sample Rate jasonschwartz Pro Tools M-Powered (Win) 1 01-11-2007 11:13 PM
change sample rate of 96 i/o ronfinch Pro Tools TDM Systems (Mac) 0 06-15-2006 03:19 AM
how to change sample rate?? remains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-28-2002 04:38 PM
Change Sample Rate in HD? Steven Sena Tips & Tricks 2 08-10-2002 06:33 PM
