Hey there. I am hoping some of you audio engineers out there could help me out. I remember learning about shifting one side of a stereo track out of phase to really "hear" (ie. cheat) what is going on in a mix and to isolate instruments. Is there any way to do this to isolate drums (which are usually all over the mix)? For instance, I am trying to isolate the drum kit on a Beck tune for a project I am doing. I am able to isolate the other stuff (sitar, guitars, SFX) but the drums are either totally there or totally not.
I split the stereo into 2 mono tracks panned hard L and R respectively. Then I switch the phase of one track, and I can get some isolation. Does this sound right? any other tricks y'all can pass along?? Thanks. --Matt |
Why don't you use a gate, kick drums are very easy to gate because of they're sharp attack and decay.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
AFAIK the procedure you outline is used to remove sounds from the centre of the stereo field (usually the vocal). The theory being that any sounds with equal components in the L and R channels will be cancelled when one channel is phase inverted. In reality, this is not foolproof as FX (e.g stereo delay) are rarely equal in the L and R channels.
It seems highly unlikely that this method would be successful for a stereo kit which, as you say, is likely to be panned unequally. http://www.myspace.com/philogg |
That technique only works to eliminate things that are mono in the mix. By inverting one channel you basically cancel out the waveform. It's done sometimes to remove vocals from mixes. It would depend on the mix whether it would work or not. A lot of times even drums aren't centered, and the stereo room mics would definitely still be in the mix.
Len |
Trick-Bug or How do we in 11? | DetroitT | Pro Tools 11 | 6 | 07-07-2013 02:23 PM |
Phase shift when using parallel aux tracks | Sydney Galbraith | Pro Tools TDM Systems (Mac) | 3 | 11-06-2012 02:23 PM |
Elastic Audio phase shift on multitrack drums | Bart HLH | Pro Tools TDM Systems (Mac) | 33 | 12-31-2009 03:10 PM |
Explanation for FORMANT shift in Time Shift Plug In, please! | Darney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-13-2007 11:00 AM |
Phase shift | rageagainst | Pro Tools TDM Systems (Mac) | 8 | 01-03-2005 06:42 AM |
