Old 05-22-2007, 07:24 PM
DHS DHS is offline
Default wierd error protools wont start
im on a macbook. running Le 7.1.1
10.4.9
I installed the latest core audio .7.3 and now i cant start protools
It is telling me that this version of protools needs version 5.1 or later??
i have went to teh answer base and nothign relates to my setup.
Any suggestions?
Old 05-22-2007, 08:35 PM
DHS DHS is offline
Default error protools wont start
update:
I reinstallled PT and it will fire up now, but for some reason every drive i own.. is says its not a valid audio record volume. These are the same drives i was using for the last 3 months with no problem and they work fine on my HD system. I have trashed all DDB files and protools preferences
Old 05-22-2007, 09:03 PM
Slim Shady Slim Shady is offline
Default Re: error protools wont start
How did you update your CoreAudio and not your ProTools app? Did you use the standalone driver? That's not for use if you have PT installed, as noted on the download page:
"For Owners of Supported Digidesign Hardware on Mac OS X 10.4 "Tiger" That Do Not Have Pro Tools Installed
The Digidesign CoreAudio Driver is an option (checked by default) during the installation of Pro Tools. If you have any of the following Pro Tools versions, you should use the Digidesign CoreAudio included with your Pro Tools installation:" Pro Tools HD 7.x
Pro Tools LE 7.x
Pro Tools 6.9.2 for HD Systems
Pro Tools LE 6.9.2
This download is for owners of supported Digidesign hardware on Mac OS X 10.4.x "Tiger" that wish to install the Digidesign CoreAudio Driver without installing Pro Tools.
I would uninstall the standalone driver if possible, then re-install ProTools and CoreAudio driver using your latest ProTools installer only.
Old 05-22-2007, 10:43 PM
DHS DHS is offline
i see.. i looked over that. regardless. unistalled using the digidesign installer. reinstalled. all is well again
thanks for your help
Pro Tools gives me an error and wont start RBM01991 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-05-2011 01:33 PM
Protools le 7.4 wont start plz help MELLINIUM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-09-2009 07:48 AM
Downloaded PT 8 and it wont start PT logo moves but doesnt start????????? protonneutron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-30-2008 03:25 PM
Pro-tools wont start error 1115 d3drocks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-01-2008 05:28 PM
003 factory memory location wont work and tab transit wierd nossnevs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-26-2007 04:55 PM
