Old 07-12-2005, 10:05 AM
magilbert magilbert is offline
Default RMX drums not syncing with internal click track
Hi. I'm running a TDM Mac system, and need to delve into Midi for first time. So I set up a synth playing a one-bar loop, taking midi time-code from Protools, and it seems to record fine and dandy as both midi and audio. Imagine my horror when I left it running for 5 minutes, to discover that the longer it runs, the more out of time it gets with the internal click track. AND, same happens with my imported RMX drum midi files. They all run fine for first couple of minutes, and then start to drift (except SOME of the RMX files stay with the click). Is there some setting I've screwed up? Might not having it set to GRID initially have caused this? Or something in Beats/Bars?
Old 07-13-2005, 03:36 PM
M.A.I.N. M.A.I.N. is offline
Default Re: RMX drums not syncing with internal click track
Where is the internal click coming from? An audio track? You need to choose your tempo first before you start doing stuff and stick to the grid. With 6.7 they introduced tick based audio so you could change the tempo of the whole track, even the audio files since they are based on the ticks of the grid. Set your grid mode to bars|beats and see if your click sticks to the grid, if it is off then this is your problem.
P4 2.4 GHz 1 Gig RAM
DIGI 002, Reaktor 5, Reason 3, Waves Gold
Slang Music Group
Old 07-15-2005, 09:38 AM
Thanks for that. Turns out the RMX files are all slightly different lengths, tho they look identical at most zooms, when you zoom in real close there are tiny differences that magnify over time. Doesn't explain my synth lines also slipping tho, so will try this tip. Much obliged.
Old 08-01-2005, 02:47 AM
twilight twilight is offline
have you got midi beat clock enabled,and stylusRMX selected to recive it?
syncing click to an imported track abbiehuxley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-17-2008 08:15 AM
Syncing midi drum machine to RTAS Click Track espada3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-11-2005 07:58 AM
Click Track & Live Drums Big Tyme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 12-30-2002 02:09 PM
MIDI track and click syncing MrMike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-07-2002 05:11 AM
internal click track revealed!!! unclemurray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-26-2000 11:47 AM
