Could someone tell me how you would go about phase revsering in protools.
sorry for the noob question cheers, R |
mixing boards have buttons (good boards) for phase reverse, but since you also said phase shifting, i wanted to mention that i had seen a plug-in that had 360 degrees of phase shifting but i was thinking that this is not possibly accurate unless the signal is a continuous wave.
just for thought.
If you don't like laughing at yourself, I will be happy to do it for you. Da-nick-str = Nick Dellos |
You can invert the polarity of an audio track several ways. Here's a few:
Destructively, you can use the RTAS plug "Invert". Or you can use DSP for real time audition-able, automatable, and non destructive polarity inversion. Many plug ins have polarity switching options. I'm not in front of my PT rig right now, so I can't give a list, but it shouldn't take too long to find a plug in that has a polarity switching offered as a parameter. Try the EQs? Anyway, keep in mind that while DSP processing is non destructive, and offers other options, unless you have Automatic Delay Compensation running on your rig, using DSP to invert polarity will result in a short delay (latency). While it might not change much in the pocket of a guitar track, for example, usually people are inverting polarity on tracks that have some audio coherence with another track, (like another part of an M/S signal, or acoustic leakage from a source which was close miked on another track, etc) with which they are hoping the inverted track will interact. In that case timing is critical, and the small delays that result from (non ADC aligned) DSP processing must be addressed. Since polarity inversion is a simple "flip", I don't feel badly about using an RTAS plug in several times on the same piece of audio. I wouldn't, for example, boost 2kHz +3db on an RTAS EQ, decide I didn't like it, and then RTAS a 3db cut at the same frequency to get rid of it it - I'd just undo the original - something you can't always go back and do easily an hour later. With a polarity inversion, I feel OK about flipping it over rather than undoing it. Not convinced? Then get the original out of the audio bin! The point is that polarity flipping is a process for which I consider RTAS' "invert" to be a good candidate. By the way, the reason I'm being picky and saying "polarity inversion" rather than phase, is that phase is variable in more ways than simply "180 degrees out" (polarity inversion). If you're talking about a two state "phase" control (like the button on a console) its really a polarity inversion switch, which is only one of many ways to manipulate phase. I hope this was helpful. |
so if i wanted to create this efect, what would you suggest.
http://www.recordingeq.com/rw/tip7.html |
Insert a Digi one band eq on the track you want to invert the polarity ("phase") on.
Click the button that looks like a zero with a diagonal line through it . If your track's stereo, click both buttons so the two sides of the stereo signal are in phase. That's a simple answer, PTUser NYC's reply is worth taking the time to fully understand though. |
rageagainst,
I have used the technique described by your link. It can sound pretty good. Record then pan exactly as the link directions say. Then, on the distant mic panned right, put on an RTAS 1 band eq and push the phase button. Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
cheers guys, that really helped.
RA |
Time adjuster does it (polarity inversion) with a minimum of 4 samples delay.
Mark Haliday Engineer, Mixer, Writer, Teacher Pro Tools Ultimate HDX Mac Pro 2013 & Chassis |
![]() Quote:
There is a hardware "Little Labs" box (IBP). |
Phase shift when using parallel aux tracks | Sydney Galbraith | Pro Tools TDM Systems (Mac) | 3 | 11-06-2012 02:23 PM |
shift/alt/3 ???? | basslik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-28-2010 10:02 PM |
Elastic Audio phase shift on multitrack drums | Bart HLH | Pro Tools TDM Systems (Mac) | 33 | 12-31-2009 03:10 PM |
The old Phase Shift trick... | kravinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-10-2008 03:56 PM |
Explanation for FORMANT shift in Time Shift Plug In, please! | Darney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-13-2007 11:00 AM |
