Please Help: New Avid PCIe Card added to old Core and Accell cards not working!
HELP PLEASE!!!! I have added a new AVID PCIe Accell card to an existing older set of Digidesign cards that were manufactured a few years ago (One Core card and one Accell card). My Mac is a 4 core Intel running at 2.66 GHz on OS 10.4.11. I am running Pro-Tools HD 2 system and I am trying to add another Accell card to gain some more processing power of course. I installed it correctly (I have done it several times before on other systems with 100% success, but never with a new card combined with older cards), and it is not working! It will not even let me do a Digi-Test before the Mac gives me the multi language reboot prompt. Am I missing a step? Is there some new drivers I have to install for these newer cards, or firmware that I am missing? My Mac and Pro Tools were running great before installing this new card and I have had very little trouble over the years, but I will not rule anything out at this point. This is my second new card in about a week to try this with... PLEASE HELP, ANYONE THAT HAS SOME KNOWLEDGE OR EXPERIENCE WITH THIS ISSUE!!!
Sterling Winfield Producer/Engineer |
Re: Please Help: New Avid PCIe Card added to old Core and Accell cards not working!
Are the older cards also PCIe Accel?
Lynx Hilo Thunderbolt 2013 Retina Macbook Pro 2.7 16 GB of RAM PTHD 11.3.1 OSX 10.10.1 |
It's an intel mac, so it has to be PCIe.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
Are you sure you seated the Flex Cable right? Also, did you put the Core card in the 1st slot?
Yepp, must be issues with the Flexicables.
There should be no problem mixing cards from different batches / manufacturing years. And yes, Intel Mac Pro´s are PCIe only.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
You are correct. I guess I should have read the post more carefully. That's what happens when you decide to post on the DUC when you're overtired.
Lynx Hilo Thunderbolt 2013 Retina Macbook Pro 2.7 16 GB of RAM PTHD 11.3.1 OSX 10.10.1 Last edited by drumster; 07-09-2011 at 05:13 AM. Reason: Spelling error |
Yes, everything was seated properly. I have triple checked all of that. The only other thing I can think of is that the last card slot is bad. Is there a way that can be checked before I have to take to my computer guy?
You could replace the working Accel card with the new one to see if that will work. Then you know there is no problem with the card itself.
If there is a problem with the card, Avid should have a flat rate repair charge.
I have taken my older Accell card and TDM Flex-cable out of the computer completely and put the newer ones in it's place. It still does not work and is doing the same thing as before. The multi-language reboot prompt. I looked at the System Profiler on the Mac earlier with all cards in, and all of the slots are working because the System Profiler saw all three cards plus the video card. Still no luck here. This is my second PCIe Accell card and Flex-cable within a week, and they are still not working. Just not sure what else to do. Is there some new drivers or firmware that I am missing for these newer cards that I do not have?
AVID HD NATIVE PCIe CORE CARD CHEAP!!! | Killbert | Buy & Sell | 0 | 01-09-2014 06:44 AM |
PCI-X CORE Card and 2 Accell Pci-X Cards | Zeljko2 | Buy & Sell | 3 | 10-24-2013 12:29 AM |
Digitest - Slot #0 Core Card PCIE - Failed but Pro Toools is working fine. | DrFord | Pro Tools TDM Systems (Mac) | 3 | 06-19-2011 11:20 PM |
Mac Pro Dual Quad core compatable with HD pci core & accell cards? | PT8716 | Pro Tools TDM Systems (Mac) | 3 | 06-28-2010 07:35 AM |
Chips on the Accell PCIe cards | bad jitter | Pro Tools TDM Systems (Mac) | 3 | 01-14-2006 10:59 PM |
