Trouble getting MOTU Ethno Inst. to show up
hi, i'm running LE 7.3.1 and did a complete install of MOTU Ethno and can't seem to get it to come up as an RTAS plugin. i've got it up fine as a VST plug in Cubase etc. but want to use it in PT. for the VST i had to move the dll file into a VST folder in Cubase to see it. do i need to do something similar in PT? i've looked for a folder that would make sense to put a dll file into but not sure where it should go. a bit confused. thanks!!
Re: Trouble getting MOTU Ethno Inst. to show up
You shouldn't have to move any dll files to get it to work so check to make sure it installed correctly. I don't remember if Ethno asks which version(s) to install - whether VST or RTAS - but some plugs do. I didn't have the same trouble but was using PT 6.7 at the time i installed it.
If you want to move the dll files, your plug-ins should be in: System Drive/Program Files/Common Files/Digidesign/DAE/Plug-Ins Hope that helps! Tom
Tom Lynn my music: www.tomlynnmusic.com other people's music: www.headphonomenon.com |
yeah, that's where it is. i can't remember if it installed there or if i put it there myself when troubleshooting this. anyway, thanks for the advice! i'll keep at it.
also note that the RTAS version needs the included iLok to run. Make sure you have the latest PACE drivers here.
MOTU Ethno-PT8 and an Issue-Need Help | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-04-2009 10:02 PM |
Problem: MOTU Ethno Plug-in sluggish / freeze | tridev | Pro Tools M-Powered (Mac) | 2 | 09-11-2008 06:40 PM |
Motu Ethno Inst. and Protools 7.1 midi question | RuffJazzRecords | Virtual Instruments | 2 | 06-12-2007 10:04 AM |
motu ethno instruments | kymn22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-11-2007 08:59 AM |
motu ethno instruments | kymn22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-11-2007 05:31 AM |
