Old 01-14-2014, 03:06 AM
phillyt2k phillyt2k is offline
Default Dragging a stereo sample to a mono track
Ok If I drag a stereo sample from the work space to the edit window, and there are 2 mono tracks there, it splits the signal and puts the left on one track, right on another.
Now if I hide all my tracks so there is only one mono track, and now I drag over the sample it just gives me the one track.
Basically, is this a way of having a stereo track be mono? or does it give me half the signal ?
Old 01-14-2014, 04:53 AM
Stig Eliassen's Avatar
Default Re: Dragging a stereo sample to a mono track
No, it discards the right channel. You should see "file name.L" on the clip.
Old 01-14-2014, 05:23 AM
ahhhh I see, I wasnt zoomed in close enough to read the full name. cheers is there a quick and easy way to convert a stereo track to mono or is it just track>split to mono?
Old 01-14-2014, 05:38 AM
I just right-click the track name, and split the clip.
If you need both channels combined into a mono file, I don't know of any other way than recording to a mono track.
Old 01-14-2014, 06:27 AM
JFreak's Avatar
JFreak JFreak is online now
Create a new mono aux track, send that stereo file to the mono aux track, there you have your mono stuff available (realtime, no bounce).
Janne
Old 01-14-2014, 08:40 AM
sw rec sw rec is offline
On a stereo track, pan both channels to center. It isn't a mono FILE this way, but it plays back mono.
Old 01-14-2014, 08:42 AM
JFreak's Avatar
Most of the time yes, but I have found there are some strange circumstances where this leads to comb filtering kind of harshness, so I nowadays do what I suggested earlier. Summing like that seems to be better, but I will stand corrected if it's just me.
Janne
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 05:36 AM
Trigger a stereo sample from a mono channel w/sound replacer bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2007 09:38 AM
Dragging a stereo track to a mono track duanebonney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-22-2002 08:17 AM
Stereo track vs. Mono track vs. Stereo Interleaved track >>>>>>>>>>> peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 06-26-2002 03:21 PM
can you not copy automation data from a mono track to a stereo track? Felix Tips & Tricks 5 04-09-2002 06:32 PM
