Old 02-04-2023, 08:59 PM
Unoute Unoute is offline
Default Channel Page default Tab help needed
Hi
I have a Dock and I am trying to do the following.
Let us assume my Tablet is showing the Mixer Screen and I would like to program a softkey to edit my EQ Settings. I need the Tablet to open op the Channel page on the tablet and default to the EQ Section of that screen. I do the following.
• I Setup up following command to take me to the Channel page on the tablet. Surface -> Avid Control-> Visible View -> Channel.
So far so good but I can not find a way to make the chanel page open with the EQ Tab already selected. This only seems to be possible if I touch the EQ Tab on the Tablet screen. This is also valid for all other options in that segment of the channel screen on the tablet. (Inser/Input/DYN/EQ/AUX/ PAN (This is the default Tab) / GROUP/MIX/HEAT/Instrument)
Am I missing something or is it just not possible with the current version of Eucontrol ?
Old 02-04-2023, 10:43 PM
its2loud its2loud is offline
Default Re: Channel Page default Tab help needed
Originally Posted by Unoute View Post
Hi
There’s a new setting in EuControl 2022.12
Improvements for Function Views while Navigating Among Track Types
Read about it here on pg.14
https://resources.avid.com/SupportFi....12.pdf#page14
It allows you to recall specific function views by track type. This should achieve what you’re looking for depending on your preference setting.
Old 02-05-2023, 06:52 AM
Hi Its2loud
THX for pointing this out to me, looks like a nice improvement to the previous behaviour but unfortunately this does not solve my issue. What I am aiming to do is recall specific tabs/combinations depending on if I am working on the EQ or if I am working on the Inputs/sends etc…..
Just like you can set the Surface to Jump to the Channel Pag I would like to be able to also set what Tab in the Channel page it defaults to.
I tried your suggestion, but it only works for one Choice at a time, and it only keeps this option saved for as long as I do not restart my computer or eucontrol. Sadly, the tab chosen cannot be saved in a layout so using the layout function to recall different tabs does not work either ☹.
I guess what I am trying to do is not possible now but maybe in a future update ��. Nevertheless thanx again for offering your assistance. Have a niche Sunday ��
Make channel page follow the S1 page selection? Frank Kruse Avid S1, S3, Dock and Control App 5 08-06-2021 10:08 AM
Jumping to a Soft Keys page from Channel? Cheesehead Avid S1, S3, Dock and Control App 0 02-14-2019 08:19 AM
Default Channel View ? priorytools Avid S4/S6 3 06-25-2018 05:04 AM
Multi-channel plugin default 'channel view'? Floydio Tips & Tricks 1 11-26-2010 10:47 AM
Can you change the default channel order of an interleaved.. dj_grimmace Post - Surround - Video 4 11-12-2007 08:10 AM
