Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 12-06-2022, 02:03 AM
Paulienat's Avatar
Paulienat Paulienat is offline
Default Ram Upgrade on Mac Pro 2019 for 96khz
as a composer I'm using many virtual instruments and heavy sample libraries on 96khz sessions, like Spitfire, Keyscape etc...so it happens that I use all the 48gb of Ram on a Mac Pro 2019 12 core.
I've also noticed better ram performances on Ableton Live, looks like PT on this combination of processor and Ram is more cpu/ram demanding.
And obviously at 48khz it takes half the amount of Ram on the same session.
Anyway I want to upgrade the Ram filling all the 6 modules left available.
I can add 48gb (8gbX6) with a total of 96gb or (double the price) add 96gb for a total of 144gb, but I have the feeling that 144 gb is an overkill because of the cpu performance limits that probably I would hit in any case.
Any feedback out there?
Thanks
Mac Pro 2019 - Monterey - Macbook Air M1 - Apollo 8p (x2) - Apollo Twin X - Ferrofish 16Mx - Avid S1 Multi-unit
Old 12-06-2022, 02:33 AM
Default Re: Ram Upgrade on Mac Pro 2019 for 96khz
Unclear exactly what DIMMs you have installed now. Or if you are looking at exactly the same make/model DIMMs. You maximize performance when you populate each memory channel equally and reduce risk of problems by matching exact make/model/part number across all DIMMs.
I am not sure these is a simple relationship between sample rate and memory usage.
You might be low on memory, but how are you determining this? Does Activity Monitor showing memory pressure happening? What problems are you seeing? Looking at memory used/free can give an unrealistic idea about memory use as apps will just tend to bloat, consume lots of memory until put under some memory pressure.
Have you looked at major uses of memory? What is disk cache set to? How full (look at the disk cache meter) does it ever get? Are all the VI samples streaming? Any have tunable memory cache/buffer settings? Any non-streaming VIs with large memory buffers/servers? Things like web browsers running? Chrome can eat GBs of memory.
I doubt anybody here can guess what you are doing--enough to then recommend how much memory you should buy. Or have any useful feel for when that might become CPU bound? But you can maybe start by making sure you are looking at memory use of your system as best you can.
Old 12-06-2022, 04:47 AM
uptheoctave uptheoctave is offline
I can't recommend what you do, besides putting in as much RAM as you can justify, although the 2019 Mac Pro can take so much RAM that you will reach a point of diminishing returns.
I upgraded from 160GB to 256GB recently and I did notice a small performance improvement but that is probably because I was mixing 8GB DIMMS (Apple) with 32GB DIMMS (OWC).
I may well have had better performance just having 128GB of RAM using only the OWC DIMMS. At some point I should benchmark this. If I do I will report back.
James Richmond
2019 Mac Pro
Avid HDX, MTRX, Focusrite Rednet PCIER, Red 16Line, UA Apollo X8, Trinnov MC8 Pro.
Old 12-06-2022, 05:52 AM
Paulienat's Avatar
You're absolutely right, I understand.
My setup is a fast external SSD just for libraries and another, same type, dedicated external SSD for the sessions (both 1000 mb/s). Plus the internal 1 Tb SSD (around 4000 mb/s) for the system and software. UAD Apollo Rack Multi-Cascade TB2 setup. Protools Studio. Avid S1 2 units system.
I check the Ram usage both from Protools Meter and Activity Monitor. No background app excpet for the UAD Console and some random Safari browsing that, in my case, don't affect the Ram monitoring percentages.
But I think it would be too tricky to go into more details.
I think I asked the wrong question:
I'm curious about the RAM/CPU balance that other PT users have found in their workflow, especially on a Mac Pro 2019, while working with big Virtual Instruments / Sample Libraries. If anybody has a similar setup.
Old 12-06-2022, 05:59 AM
Paulienat's Avatar
Nice to hear from a Mac Pro 2019 users
Do you think is because of the mix of two different sizes of Ram Modules on the same pair or for for having two different manufacturers, OWC + APPLE?
In my case I'm going to have 6 gb APPLE + 6 gb OWC, all of the same size (8gb), for a total of 96 gb.
Old 12-06-2022, 06:24 AM
Well, Apple say 'Use the same size memory modules across all slots to maximize performance.'
Others have reported issues mixing RAM brands, although I am not sure if that is true.
Someone else might be able to comment.
I actually have 6x Apple DIMMS in 8GB each that I'd do at a decent price for you.
They came out of my system- bought with the machine, I was one of the early adopters (first outside Avid and Apple to have a working HDX system I think) so the OWC RAM wasn't available when I bought the machine.
I'm in the UK.
But for myself, I didn't go down adding more 8GB DIMMS once the larger ones were available.
32GB is the sweet spot- OWC do them for $270 a pair of $530 for four.
Leaves room to expand down the line.
James Richmond
2019 Mac Pro
Old 12-06-2022, 10:30 AM
But what numbers are you looking at, again memory used and free metrics may not be telling you what you think they are. The system is not actually low on memory unless you see the memory pressure graph come out of the green. Is it? Are you getting memory or CPU errors? Stuttering, other VI problems? Adding memory will not hurt, more memory is great, but I am not hearing for sure if you really need to do this.
Old 12-06-2022, 11:18 AM
The Weed's Avatar
The Weed The Weed is offline
As an aside, would Vienna Ensemble Pro solve any of the OP's issues?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-06-2022, 02:04 PM
I also posted some other comments on memory usage recently. https://duc.avid.com/showpost.php?p=...0&postcount=15
Maybe most useful there is mention of boot-args="maxmem=xx" and the memory_pressure utility that can help show how much more memory you have than might be needed to just do the job. If you suspect you are low on memory, deconfiguring say 8GB or 16GB and just see what happens can be useful. May or may not be helpful here, but might help others.
The complexity with VIs is not only is the DAW causing memory use and the operating system potentially then reducing then amount of physical memory actually used but the VIs are also managing memory, how much they allocate to memory resident sample caches or streaming buffers. Some may be configurable, some may be configured by the software based on systems configs, I'd expect some might change themselves if the system is running low on memory.
Old 12-06-2022, 03:23 PM
JFreak's Avatar
JFreak JFreak is offline
^ What he said, memory pressure is very useful. Also installing "htop" terminal tool gives you good insight what is going on, it also shows CPU utilization on core basis, (all in one terminal screen).
Janne
Upgrade to 2019 enfamale Pro Tools 2019 2 02-12-2020 03:05 AM
Upgrade from 12.4 to 2019 emperor of mars Pro Tools 2019 2 01-29-2020 07:33 AM
PT 2019.6 at 96Khz mutes random regions Stephen Webster Pro Tools 2019 2 10-22-2019 11:43 AM
Upgrade 2019 basslik Pro Tools 2019 3 10-06-2019 02:20 PM
