#41
![]() Quote:
It does works nicely and was able to monitor thru speakers, BIN Dolby Renderer and Logic with Apple renderer (and dolby renderer) on AirPods. Also listening from Assembler thru Logic works the same way. But without Pro Tools, only on AirPods or 7.1.4 from logic thru DVS on speakers.
![]() Mac Studio Ultra, OS 12.6.3, MTRX Studio, PT Ultimate 23.03, HDX1, Sync HD, BM Decklink Extreme 4K, Dolby Atmos Renderer, Avid Dock, S1, C|8 |
#42
![]() Quote:
I'm using this exact setup on my system. https://youtu.be/ZdM3HsHuozQ I'm working in Post. Sync feels a little soft with picture. Is this the delay compensation that can't be avoided by using the Pro Tools Audio Bridge. Also, I use the numeric keypad in shuttle mode Slight lag from scrub to actual playback of audio. If I go back to old way, PT playback engine set to Dolby Audio Bridge DAPS output set to HDX Playback is tight again. Scrub tight as well. Would be interesting if Pro Tools Audio Bridge could be accessed directly from MTRX Studio- Monitor Profile. Instead of having to bring it back in to PT. Mac Studio Ultra 128RAM, HDX Thunderbolt, PT2022.9, MTRX Studio, DVS Last edited by Dizaineris; 10-05-2022 at 03:37 PM. |
#43
Just like Dolby Audio Bridge, Pro Tools Audio Bridge is a Virtual Coreaudio Device. The Monitor Profile of MTRX or MTRX Studio can only leverage the populated IO that is available to the crosspoint matrix - and (if you have multiple MTRX devices) the unit assigned to ProMon.
Jeff |
#44
![]() Quote:
But makes sense. Thanks for answering |
#45
In the very limited testing I've done so far, I feel the same way about sync to picture.
Scott Gatteño |
#46
Tested the setup suggested without returning re-renders into ProTools. Routed the output of the Dolby Atmos renderer to Dante instead and found that there is a sizeable delay between the output of the HD Native Thunderbolt/MTRX Studio and Dante. Is this due to the inherent delay in Dante or something else?
nickcath@internet.is Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2022.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 12.6.3, PT Ultimate 2022.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
#47
![]() Quote:
https://lukehoward.com/ |
#48
Hi Luke,
Yes DVS. Actually worked from the get go! If you want my setup just drop me a line.
#49
![]() Quote:
It is working fine here too. The renderer just required some liberal restarting when messing with I/O settings to kick it back into life. Loopback tests seem relatively easy now that Pro Tools has Aux I/O. At 1024 sample buffers and 48kHz, I am getting the following: HDN + RME Madi - 56.3ms HDN + DVS - 62.6ms HDN + RME Madi + PTAB return to Pro Tools - 72.4ms DAB + MADI -> HDN - 80ms HDN + DVS -> PTAB return to Pro Tools - 87.8ms DAB + DVS -> HDN - 99.5ms DAB + PTAB return to Pro Tools - 119.8ms Adding DVS to a previous DAB in/HDN out renderer setup will add a little bit of latency, but it is very little compared to DAB or PTAB are bring to the party.
Pro Tools Ultimate 2022.12. OSX 13.2. Win 10. HDN. DAD DX-32R. DADman 5.3.4.2. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Sync HD. Dolby Mastering Suite 3.7.2 via RME HDSPe MADI. Last edited by LDS; 10-10-2022 at 01:14 PM. |
#50
![]() Quote:
Very helpful! |
Dolby Renderer sync issue with HDX/MTRX Studio | remainanon | Pro Tools | MTRX & MTRX Studio | 7 | 05-24-2022 02:32 PM |
MTRX Studio HDX and Dolby Atmos Production Suite | Goombot | Pro Tools | MTRX & MTRX Studio | 64 | 09-30-2021 01:02 AM |
What brings Dolby Audio Bridge to HDX users? | nedd | Post - Surround - Video | 29 | 01-03-2020 03:24 PM |
Dolby Audio Bridge and AVB | RSLAMBERT | Avid S1, S3, Dock and Control App | 0 | 11-03-2019 01:46 PM |
Dolby Media Producer Suite v2, Decoder, How to get audio to my SPK w HDX and MTRX rig | bsteeve | Post - Surround - Video | 3 | 08-16-2019 06:19 AM |
