Old 04-30-2022, 12:53 PM
WinstonDeath WinstonDeath is offline
Default Artist Control Soft Keys Not Functional when Control App present
When using an Artist Control in conjunction with iPad Control App in Eucon 2020.4, the presence of the iPad seems to halt functionality of the soft keys on the MC.
Old 05-02-2022, 05:11 PM
thesoundguy77 thesoundguy77 is offline
Default Re: Artist Control Soft Keys Not Functional when Control App present
can confirm same issue here with latest pro tools and EuControl 2022.4.
Physical soft keys on the Artist Control get bugged/frozen as soon as you connect a Control App.
this has been an intermittent issue over the years, usually solved by adjusting the surface order in the My Surfaces section and making sure the Control App is listed above the Artist Control. (or sometimes just the act of changing the surface order can fix)
in this case with the newest version, the surface order fix only partially solves the problem—
by adjusting the surface order, I am able to restore the soft keys on the artist control from being completely frozen, and basic pro tools based commands start working again (like preview, automatch, etc) but Eucon specific commands (like jump to page, jog wheel assignment, layout recall) still do not work from the physical soft keys on the artist control.
but they do all work from the touch soft keys on the control app.
I know the artist control is no longer officially supported, but hopefully the fix isn't too hard for this so we can continue to limp it along a little bit longer.
Old 05-05-2022, 06:54 AM
EddieJones's Avatar
What OSX version are you on!?
Sent from my SM-S908U using Tapatalk
Old 05-05-2022, 02:10 PM
Catalina — 10.15.7!
Old 05-06-2022, 08:48 AM
EddieJones's Avatar
Anyone seeing this, please drag the Avid Control App to the top of the My surfaces list and report back.
Old 05-19-2022, 05:29 AM
FlorianE FlorianE is offline
Great! Such a simple little trick. Finally able to use both at the same time..
Old 12-04-2022, 05:36 PM
Lcepeda Lcepeda is offline
I am still experiencing this issue, but on my avid dock and avid control. My soft keys won’t work when avid control is present. The 12 physical button do light up ant times on the dock but i can not see the soft keys on the avid apo. It only seems to work for A little when I focus on another window other than the daws Which I’m this case is pro tools. Any help would be greatly appreciated.
Old 12-05-2022, 08:52 AM
EddieJones's Avatar
This is not the same issue. Is your DAW locked on the Assign page? Are you getting tracks on Avid Control. Look in the About page for what App it thinks is connected too.
Control app soft keys not working as expected ballandbiscuit Avid S1, S3, Dock and Control App 2 09-13-2021 09:27 AM
Control app channel view and soft keys. Orchook Avid S1, S3, Dock and Control App 5 02-10-2020 07:27 AM
Soft keys right hand side not functional in Pro Tools RogerPaolo Avid S1, S3, Dock and Control App 5 01-24-2018 05:44 AM
D-Control Soft keys section LED problem Vedat ICON & C|24 3 02-22-2017 12:38 PM
FYI — PT | Control + Artist Control simultaneously — soft key weirdness thesoundguy77 Artist Series 4 11-11-2016 09:10 AM
