Old 12-15-2013, 07:16 AM
Smico Smico is offline
Default ProTools ignores Limiter Ceiling
Hi everybody,
I recently went from the good old 7.4 to 11 and I'm stuck with a strange issue.
I have a project with a clicking sound (that is supposed to be there) in the original recording from the set.
So I told my waves L1 to cut those clicks at -0,1, after going through the AIR reverb. It didn't care at all, still 0,0 and clipping.
Well, maybe a minor glitch I thought, so I went down to -0,2...and even -1,0 - was still clipping at 0,0. Everything checked in the Master Fader.
Then I tried to send it to an Aux and put the Limiter on it. Same issue.
Same thing with maxim.
Both ways worked perfectly fine in 7.4 - what has changed?
Thanks in advance.
Old 12-15-2013, 08:41 AM
guatamas guatamas is offline
Default Re: ProTools ignores Limiter Ceiling
Is the Limiter the last insert in the chain? Anything after a limiter would cause clipping if the signal is too hot
I have heard that the internal mix bus had changed in PT 8 compared to 7 where in 8 0 meant absolute 0 so any thing above would cause clipping, in 7 you would have slightly more headroom so opening projects from earlier versions of Pro Tools would "sound" hotter. I could be wrong though.
Old 12-15-2013, 10:24 AM
Thanks for the answer. The limiter is the last plugin in the chain, automation is untouched.
Old 12-15-2013, 10:45 AM
crizdee's Avatar
crizdee crizdee is offline
Are you sure your master fader is on 0.0
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-15-2013, 11:21 AM
Top Jimmy's Avatar
Or are you viewing input metering or output metering?
James Cadwallader
Mac Studio, 64GB RAM, 1 TB SSD, Glyph 2TB USB3 HDD, OWC drive dock, Mac OS Monterey 12.6.2
Pro Tools Ultimate 2022.12, HD Native, Focusrite Red 8Pre
Old 12-15-2013, 11:49 AM
lexaudio lexaudio is offline
The l1 isn't a brick wall limiter either. Really high frequency transients get through sometimes.
As said make sure you are post fader metering.
Old 12-15-2013, 12:02 PM
Drew Mazurek's Avatar
If you post your session (without audio) we can check the routing etc.
www.drewmazurek.com
Old 12-15-2013, 03:01 PM
Chief Technician's Avatar
Exclamation Re: ProTools ignores Limiter Ceiling
Agreed.
Old 12-19-2013, 08:57 AM
Yes, the Master Fader is at 0.0
Output Monitoring. I even imported the bounced file and analyzed the peak via Gain-Tool (0.0 dBFS). In Premiere it was clipping as well.
Thanks for the offer about the session, I'll gladly get back to it in the next days. I just need to make a new session and be sure, there are no infos left to compromise the NDA.
@l1: Good to know, thanks. Which limiter would you define as a "brick wall" then? Then I could test it beforehand.
Based on your replies, this is an issue none of you experienced? So it's not a "feature"?
jfi: Is the ceiling of the maxim reliable? This one failed too.
Old 12-19-2013, 11:21 AM
Craig F Craig F is offline
Maxim reliable, funny
Take a look at the new Avid Pro Limiter, it was mad with broadcast in mind
http://www.avid.com/US/products/pro-limiter
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Session ignores mic inputs mgmazzei Pro Tools 10 4 05-02-2013 09:51 AM
Can I use the limiter from ProTools for live recordings? PetrosGls 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-03-2008 03:17 AM
LImiter on audiotrack Vs Limiter on auxiliar track cinetj General Discussion 2 07-15-2008 11:15 AM
'Digidesign Ignores Matrox!' Read all about it! K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 46 11-21-2005 12:47 AM
favorite software limiter on protools mix buss? fourthtunz Tips & Tricks 6 09-03-2005 08:42 AM
